Oneway versus McNaughton
Starry Chan
Because of my trouble with the Oneway Easy-Core #2 support blade, I start thinking about the need for the support blade.
With the McNaughton coring system, the cutter blade is supported by the gate near the entry point. There is no support as the blade is pushed into the bowl blank. With the Oneway, the cutting blade can also be supported by the support blade or the support blade post at the entry point without advancing it as the cut progresses. It looks likes that the Oneway blade is also constructed heavier than the McNaughton blade so it should be able to cut without the support blade under it. The cut will definitely be more stable if the support blade is advanced. However, I am wondering whether the support blade is really needed.
Starry
