OneWay Easy-Core #2 knife problem
Starry Chan
I am having great problem with the #2 knife. Here is the details.
The top of the cutter is aligned with center line of the spindle. The height of the support blade is adjusted so that there is no gap between the knife and the support blade. As I advanced the support blade, both edges will start touch either or both sides of the kerf. I widened the kerf by 1/16" to 1/8" but this does not solve the problem. I should not have to widen the kerf in order to advance the support blade. At this moment, I have a blank on the lathe with a 1/2" kerf and the #2 support still bind in the kerf. If looks like the welding of the support blade was titled too much.
I contacted CSUSA and they think either the knife blade or support blade may have been bent. I really don't see how these blade can be bent. They are sending me a replacement so I will be able to compare the two sets.
I would appreciate your sharing of your experience.
Thanks,
Starry
Re: OneWay Easy-Core #2 knife problem
robo hippy
If you move the pivot post to either side of dead center (between the ways) on your lathe, you can get this type of binding, especially if you are coming in at an angle rather than square to the face of your bowl blank. The exact arc of these cutters is pretty specific, and if you deviate from the perfect arc, you end up with a square peg (the blades) in a round hole (the kerf). You can check to see if either the support finger or blade are bent by putting the flat surface on your table saw. or other flat surface to see if there is any arc. You could also draw a circle the same as the diameter of the coring blade and see if the support finger lines up with the radius at center height. The weld to the post could be off. Also, the blade and support finger should lay flat against each other, not one side high, and the other side flush. Other than that, not sure.
robo hippy
Starry Chan
The mother bowl is 14.5"x6.5". The pivot post is at dead center to core out a center of 11.5" in diameter and 5.25" deep. The wall thickness of the outer bowl is 1.125". The bottom thickness of the outer bowl is also 1.25" as the pivot post is only 1/32" away from the surface of the bowl. The original kerf is 3/8" but I widen it to 1/2".
The binding starts when the kerf is about 2" deep. It gets progressive worst as the kerf gets deeper. I can visually see that the support blade is tilted so that its two edges rub against the two sides of the kerf. This is the case even after I widen the kerf to 1/2".
CSUSA is going to send me another #2 knife set. I will compare it with the current one to see whether they are made the same way. BTW, I do not have this problem with #1 knife. I do not have #3 knife so I do not know whether it behave the same.
This is no indication that the blade is bent. I really do see how it can be bent as it takes a lot of force to bent a 1/4" 60,000 lb tensile steel.
Starry
