Burning and wire brushing
Don in Central Illinois
Sometime ago, I think I remember someone showing an ash bowl thst they had semi burned with a torch and used a wire brush for texture. Would like someone to tell me how to do this. Don't want to use too much fire, not enough brush, etc. Any help appreciated.
Re: Burning and wire brushing
I haven't done much of it but you just have to play. the deeper you burn the deeper the texture. All the wire brushes are different. A brass brush will just remove the burn and leave a very subtle texture. A heavier brush will not only get rid of the burn it will leave a more pronounced texture of it's own.
I would start with a careful burn that isn't too deep and use a very light flexible brass brush and see what you thing. You can always burn more and choose a different brush on the second attempt.
Steven Antonucci
start with ash or oak... you can't do it wrong
Steven Antonucci
I burn a little, brush it out. Repeat. Do not let an ember catch. Do not blow on it if you do. Wear a mask, or you will have black boogers for a day.
Mike Peace
Mike Peace
Keep a fire extinguisher handy and do it on the lathe. Then you can easily take a final pass with a spindle gouge at the edge for a crisp delineation of the burned and unburned area. I used a propane torch and kept it moving. Go lightly and make multiple passes til you get the effect you want.
Dan Jechura
Dan Jechura
I tried it on 3 oak bowls and it creates a great texture. I use a steel brush. I mounted the bowl on the lathe. As the wood burned I turned the bowl by hand. I made sure the wood chips where cleaned up. I use a cheep blow torch used for soldering copper pipe.
Dan J.
Unfortunately, it's already off the lathe, but I may try to mount it with a jam chuck.
different textures with different brushes
Dick Coers
If you use a steel brush, you will get the most depth, but you may also have a little raw wood show through. Brass has less chance of wood showing, and nylon leaves the most burn show. Harbor Freight has the 3 brush sets with one of each of those. But, the steel brush is horrible. It's like you can easily count the wires in the brush. On my branded bead work, I always use the nylon to make sure I have an even black surface.
Clean up the shop first! *LINK*
Craig Daymon
Please clean up the dust and shavings before attempting this. I know if I were to try it right now the house would likely go up in a minute. I would suggest making sure there is a clear area all around the lathe.
Years ago I saw a demonstrator that talked about surface decoration. (I think it was Art Liestman, though I don't recall much use of wire brushes in his work.) The demonstrator said that he collected wire brushes whenever he went into a hardware store of every type of wire. When he found one he liked, he'd get several.
I remember him commenting that the brushes didn't last long. (They tend to dull quickly and are VERY hard to sharpen.)
A brass brush is probably the safest to start with as it won't be too aggressive. Also, I would start the torching with the flame just lightly licking the turning. You can always move in closer if you are not getting the effect you want. Keep in mind that, just like pyrography, certain areas will burn faster than others.
Good luck.
-Craig
P.S. I picked up one of those little cooking torches for stuff like this. A bit easier to control. Lee Valley has 2 on their site. I got the other one, but would have gotten this one if it had been available.
Lee Valley - inexpensive "Pocket Torch"
Re: Clean up the shop first!
I had alredy pkanbed on a good cleaning. My shop and attached garage would probably disappear in flame.
