When is a bowl not just another bowl?
Steven Antonucci
Steven Antonucci
When you turn it by swinging a gouge instead of holding one!
I spent a couple of aimless Saturdays forging this adze head out of an old lawnmower blade and then this past Saturday swinging it. The hollowing part goes remarkably quickly. The exterior was bandsawn first, but then shaped with a hatchet and then a drawknife and spoke shave.
It will sit in a bag to dry for a couple of weeks before I do the final hollowing and finish work. I had to learn how to draw an oval (easy to do) and then cut and oval with an adze (a bit harder than drawing one...)
Comments and questions welcome.
Steve
Re: When is a bowl not just another bowl?
Mike Stafford
Mike Stafford
That looks great. When you finish it the bowl will be spectacular. Lots of old dough bowls are fashioned in just that manner.
Roy Girolami------WebKitFormBoundary9yANUT8mn8C+Zo
I saw a demo once where the demonstrator used a chainsaw to roughly cut depth slots and then used an ax and an adze to rough it out. he finished it fairly quickly, but then he was not looking for super appearance. Definitely the way to go if you want to increase your arm strength.
Roy Girolami
Steven Antonucci
Angle Grinder attachments
Steven Antonucci
I have both the chainsaw (King Arthur) and Kutzall carbide disks. Both of them are easy to use and remove wood quickly, albeit differently.
For one, the chainsaw disk sends a shower of small chips pretty much everywhere. Clean-up is about the same as roughing a bowl of that size with the lathe. It is also noisy and I have a hard time controlling the shape. There is always one cut that went 1/4" too deep.
(I bought them to start chainsaw carving bears)
I am working on a slightly heavier adze head to overcome some of the springiness in this one. I can take a big cut by swinging harder, but I pay for it for 2 days afterwards...
S
Alan Zenreich
Re: Angle Grinder attachments
Alan Zenreich
Steve,
Nice work with the new adz.
You can gain more power, and stabilize your cut, by adding some counterbalance weight.
I suggest adding your (wait for it...) 12 volt lead acid battery. Of course, it could also power the laser...
< ducking >
Steve 2 tips on the Arbortec or Lancelot. ONe is to use a scraping motion as much as possible. Very controllable and won't run on you unless you really take a hogging cut. If you need to use it straight up (think nose of the chainsaw kind of cut) then it's very dangerous and will pull itself into the wood and run back at you. Not good.
If you need to make this kind of cut I use 2 tips. One is to rotate the blade guard around so you can rest it on the wood and use it as a bevel. This is the best tip I ever got and works fine on my off brand grinder. I can't rotate the guard on my Makita.
The second tip is to simply take light cuts, start with the 6 to 8 oclock position if you can and avoid the 9 oclock. If you have to use the 9 oclock make sure you take light cuts and hang on. Always use a plunge kind of cut to widen a kerf. If you go sideways it will start hogging wood and is far more likely to kick back on you.
It goes without saying but this is a 2 handed tool. I also try to keep my elbows next to my body for more leverage.
Last but not least on bow shapes like you've done the Holy Galahad or even 24 grit sandpaper on a sanding disc is far safer and will remove wood almost as fast.
I'm starting to work on a grinder safety article. I've been hanging out with my friend Brad Sells who uses these all day every day and knows more about not getting cut than I'll ever learn.
Brad Vietje
Brad Vietje
Cool Bowl, Steve -- and a big thank you to John for those safety tips!
Safe spinning,
Brad Vietje
Newbury, VT
Steve, you gone native!
Jorge
I have a couple bowls and a tray done by natives in Malawi, Tanzania and Kenya made that way...
Mike Stafford
Mike Stafford
When you carve bears with a chainsaw do they object? :D
Very Cool !
Don Orr
I'd like to see better pics of the adze head if you could, please.
I like the bowl very much. Have seen similar in musuems of native cultures as Jorge mentioned.
Steven Antonucci
I can barely life that battery...
Steven Antonucci
let alone swing it.
I strapped it to a standard claw hammer head and I get what you mean about weight behind the head... I am also trying to make a halfway decent looking tool. The hose clamp is temporary until I can bind it like the other ones.
I have to learn the Native binding weaves now :)
S
Steven Antonucci
No bears were injured in the making of this bear
Steven Antonucci
er um... I mean bowl
Steven Antonucci
Think spindle roughing gouge, only sharper
Steven Antonucci
I basically started with a flat section of lawnmower blade, and ground it to a skew, and then bent it to a SRG profile. There is a bevel on the outer edge that gets honed and a tang to get lashed to a handle. The tang has a very slight bend in it to line the cutting edge to about perpendicular to where it is held.
I choke up on the handle a little bit to balance it. With the prices on adzes being $150+, I figured it might be something I could make and save a couple of bucks.
I was right :)
Steve
Thanks Steve
Don Orr
I get most of the idea-not sure what you mean by ground it like a skew.
Double bevel?
Not square across the end ?
Did you harden and temper it?
Steven Antonucci
Answers
Steven Antonucci
Double bevel?
Yes, but I believe the carvers would say "in cannel", which means that the bevel is on the outside of the gouge. Think a skew ground across perpendicular, and then roll it around a round form.
It is as square as I can get it, but I don't think that's super important? It is not a fingernail... if that was what you were asking?
Harden, yes temper no. I only heated the edge back about 1/2" The rest is whatever it is. You can do this with a plumber's torch and a coffee can full of mineral oil. Dull red, check with a magnet (when it is non-magnetic, you are ready), dunk and cool. It is not file hard, but it is hard enough to hold an edge for a long time in wet apple.
The steel is probably 3/16" thick, and would have been much better if it was 1/4". It "sings" when you swing it, so I put on hearing protection and have at it.
S
Re: Answers
Jorge
Steve,
The in cannel gouges have the bevel in the flue and are a bitch to sharpen.
I did help hollowing a 60' dug out proa, a type of vessel out of a huge tulip poplar, 4 foot across the small end.
I did use my ship builders adze to shape the outside of the ends. for the inside they went the traditional way and burn fires and put them out, then we cleaned up with curve concave adzes, they got from antique shops, a fellow had a nice little one he got from Woodcraft, this was on the mid 70s. Check the Woodcraft catalog, they may still carry it, it did weight about 2 pounds and was easy to work with, held the edge forever in that green poplar.
Thanks Again
Don Orr
And Jorge is correct about "in-cannel" having the bevel on the inside of the flute and being awkward to sharpen. I believe yours is "out-cannel" like a SRG.
Leo Cuellar
Looks good!
Re: Answers
Keith Newton
Steve, You gotta loose that hose-clamp, and either dig some elm roots, or save some tendons from the next bear you kill and drag back to your man-cave. But maybe you can just buy some rawhide.
I had been thinking about making one of those, as well as a fro, but was thinking about using automotive leaf springs. I don't know how good that steel would be, but I'm sure it is better than just mild steel.
