Outside calipers - source for reasonable one?
I've got two outside calipers. Both are no-names. The 6" works well - I can't remember where I got it though. The 8" is problematic.
I use them for roughing my outside measurements on spindles. It helps to have several. Ideally I would like to have at least two more. They can be 6" or 8". I'll grind the tips off of them - but the points have to line up reasonably well.
So - any source for one or more that hold their measurements and have enough spring so they won't dig into the spindle?
Re: Outside calipers - source for reasonable one?
I found a sale years ago at GRizzly and bought a bunch of inside and outside calipers. I haven't looked to see if they still have them.
Rob Wallace
Rob Wallace
Over the years I have purchased good quality calipers from sellers on eBay. I have several pairs of Starrett (outside) calipers - some were purchased in 'new' (unused) condition for a fraction of their retail price, and others were "pre-owned" (used), but this does not detract from their functionality.
When turning spindles, I have about 4 pairs of "go-to" calipers out of a total of maybe 10 or 12 different calipers that I own, and all four of these are made by Starrett, and were purchased from eBay sellers. My favorite style is the flat leg, Starrett Model 79 outside calipers (available in 4, 6, 8, 10, and 12 inch sizes), with nicely smoothed arm tips, and with an excellent screw adjustment. These are outstanding for all kinds of woodturning needs.
If you intend to do a lot of spindles, you might consider investing in a Galbert Caliper (See http://www.woodturnerscatalog.com/p/5/-/19/86/-/4483/Galbert-Turning-Caliper/caliper ) which is an efficient and accurate alternative to having multiple calipers. For simply setting spindle diameters, you can't really improve much on the efficiency and speed if you are using one of these! These calipers are awesome!
Some excellent bargains can be found with diligent and patient searches on eBay.
Rob Wallace
Joe Herrmann
I agree with Rob. The Starrett calipers are the best in my opinion and are my go to ones. The Galbert Caliper is also an excellent tool and is worth the money if you are turning a lot of spindles requiring a number of measurements. It's not recommended for measurements under about 3/4".
Mike Mills
Mike Mills
I have a set like these but mine was made in the 50's. Still going strong. They are only four inch but I have never turned a spindle over that. A nice tool if you can use smaller.
They are very easy to set accurately and lock down.
http://www.leevalley.com/en/wood/page.aspx?p=43199&cat=1,43513,43550
I''ve got the Veritas
I've used the Galbert.
I'm happy with the Veritas - for roughing in big stuff like chair legs or stretchers.
The problem is - I often do smaller things - like Shaker pegs or back spindles. For those I prefer to use an outside caliper. We're not talking precision - though if I could find Starrett calipers at a reasonable price, I'd certainly buy them. This is just quick and dirty measurements.
My 8" outside calipers have a tendency to lose the measurement. Say I've got it at 3/4". If I put them on a turning spindle, they will eventually gain a significant fraction of an inch - say 1/8" or greater. Yes - I put the caliper on a turning spindle - works quite well with my 6". I have been known to use an open end wrench - but they don't spring around the spindle properly.
Joe Fleming
Re: found these on Enco
Joe Fleming
John, Good find. Does ENCO have a minimum order? Joe
Don't think so but while your there
buy some HSS metal turning bits. I buy 3/16 square by 3" long for about 75 cents each. They make great hollowing tools once you cut them shorter and mount them in various bars.
