gluing for later removal
bill crommett
I have been chosen to turn a baseball bat for mounting above the mantle.
What clues can you give me for gluing a piece of SPF to the oak to make a half bat for flat mounting ?
bill crommett
Re: gluing for later removal
Bill Howatt
My first try would be a layer of brown paper and white glue. After turning a chisel carefully in the joint should pop them apart. I've done this several times but never a joint as big as a bat.
Bill
Don in Central Illinois
Just don't forget the paper!
Bill A paper joint works perfectly for that. I just use newspaper. Put glue on both parts. Put paper in between and clamp it together. Let is sit overnight. The paper seems to make the glue slower drying.
When you start turning use cup centers. A pointed center can split the paper joint. When your done just use a chisel or knife and drive it through the joint.
If want the paper off you can soften the glue with White Vinegar and rub it off. I often use a cabinet scraper to get rid of most of the paper but don't get too close to the edge or you can chip out some wood.
bill Crommett
John: Do you also recommend white glue over T-B II ?
Dennis in Southern Oregon
Bill, others have suggested using a paper joint. I would just add that you might consider having the joint not on the center line of the bat, but slightly off-center so that the mounted bat has a 3-D effect. In this case, you do not have to worry about the centers splitting the joint.
Dennis
I suggest an experiment first...
Dick Coers
you will be amazed how little strength the brown paper joint has. The brown paper itself will separate with paper left on both sides of the joint. So the hint to not drive the centers in the joint is a good idea. Driving a center in will start a crack in the paper, that will open up quickly if you are too aggressive with the chisel work. Play with some smaller pieces, and wear a face shield while you test the joint.
Bill When I first started doing split turnings I used white glue. Ever since then I've use what ever I have. I have been using titebond ll for many years now with success.
I did a test a few years ago on different papers and glues. Just about any paper that tears easily will work. Water color paper did not work. I also tried paper sacks and brown craft paper. Saw no advantage over newspaper. I did try black construction paper on my shelves thinking that I could just leave it instead of scraping it off. It was black and it split in two leaving paper on both halves of the shelves but it looked very rough and unfinished so I scraped and used the white vinegar to get it off.
I could not tell the difference in the glues at all but did not try epoxy or polyeruethane glue.
Off center joints work great
When I wrote the article on making these shelves I experimented with mounting scrap between them so you get a more flattened look as well as using scrap as the waste piece mounted off center so the piece had a more 3D look. All 3 methods look pretty cool. Gluing on center or with a waste block in the middle of course gives you two identical pieces. If your making something like my my shelves of matching finials for a dresser then this is the way to do it.
For one off pieces like your bat using a scrap piece glued off center would be a good look.
I have also done split turning where I needed 1/4 rounds to go on a grandfather clock. I also made some custom replacement moulding for an old clock that was 3/4" wide and 1/4" thick and had a radius of 2". I simply glued my walnut 3/4" x 1/4" piece to a waste block that moved the walnut far enough off center. Then filled in around the walnut with waste wood to make it easier to turn. I used a thin knife to split this on off instead of my chisel because I didn't want to split the wood.
These are the shelves in my house. These were terrible sellers. I have had to give most of them away. Still have at least 3 sets get rid of.
Re: I suggest an experiment first...
I use a 4 prong drive center and predrill the center point so it won't split the joint. Then I use a cup center on the tailstock end and predrill that center point as well. I have done Dozens if not as many as a hundred split turnings and I can only remember one coming apart and it was an inside out turning that I only waited an hour for the glue to set.
I have also used glue joints to hold bowls to waste blocks back when I couldn't afford a chuck.
If you really nervous about it splitting apart simply turn an area and then put a hose clamp or strapping tape around it. I have used nothing but strapping tape to hold some inside turnings together without even gluing them.
bill Crommett
Great replys. I had considered making a 6/10 round bat to eliminate the splitting problem, and I had considered using strapping tape. I was pleased
to have my suspicions corroborated.
Thank you for the good suggestions, and now I must address the problem of getting the bat turned before my hands give out before the wood warps from drying.
I will go with the newspaper and the TB II (that is what I have in stock.
SPF? Squirrel-Proof Feeder???
Pete in Holland, MI
As was said about the center spur, I drill my wood first so there is little splitting force going on.
I also learned to ensure the 4 blade spur is rotated 45 degrees to the parting line. Lined up with the parting line, there is a splitting effect going on by 2 of the blades. Rogate it 45 degrees, the splitting effect is gone, AND you get a clamping effect to hold the two pieces together.
Also noted earlier, allow the glue to dry overnight prior to turning.
Pete
Re: SPF? Superior Precision Format, No Wait...
Sound proof foam?, No wait...
Actually "Spruce Pine Fir" Common framing lumber found at the Borgs.Those studs might be any of them. Not enough difference between them to matter for constructing a house. They cut mixed stands or whatever and sell them as lumber soup.
Should proceed fast?
bill Crommett
Thanks Barry.. I forgot that not all turners used to build houses or used 2X4s for all good projects.
