I just finished using epoxy to glue the spindle into the top and bottom of a wig stand. Of course I used too much epoxy and had to wipe it from the finished (deft lacquer) pieces. I used a paper towel and did a reasonable job of removing it. How do other handle this?? Is there a solvent that will remove the epoxy and not the lacquer??
Ed, I generally dry fit the joint and then wrap masking tape around the exposed parts of the joint before applying glue. If I remember correctly unset epoxy can be cleaned off with mineral spirits or turpentine
White vinegar is a solvent for epoxy and I don't think it would attack the lacquer. It's not as vigorous as acetone and such but it will help. It's pretty good for tool and hand clean-up without being nearly as harmful to your body.
I use Alcohol while the epoxy is still wet. I have done this for hears on my mirrors. I usually have at least one coat of lacquer on everything before I glue them up. It hasn't hurt the lacquer yet although it can dull it slightly. I'm usually applying more coats afterwords so it's not a problem.
Another vote for the white vinegar. I took a hands-on workshop with Marilyn Campbell and we used vinegar to clean up our mixing boards, etc. Never would have believed it if I hadn't seen it!
White vinegar also works very well for softening PVA glues. It will actually get dried glue out of your clothes. I haven't tried it for epoxy, but Marylin knows her stuff.
While the vinegar and alcohol may be better options, if you don't have the others close at hand.
If it is still wet,you can massage it, to mix them into the emulsion.
But, I usually like to use masking tape, then a finger to squeegee it in, them peel it while wet. Don't let it cure, with the tape on.
But if you wait until it has cured to a leather stage of toughness, a thumbnail, or other dull tools like putty knife can push it off a smooth surface.
