Has any one here ever dealt with Reeves system of variable spped lathe to adjust, or fine tune it?
My lathe has a problem that the pully on the headstock which supposed to move to the higher speed behind the reeves brakcet is stuck and I can not figure out how to get it unjammed. Any help with be greatly apprediated.
Lots of posts on line about these. Google will help you. Every one of the posts will tell you to never pry on the pulley, it will snap almost instantly! No experience, just go on a lot of turning forums and this comes up a lot.
My first lathe was a Reeves-drive JET 1236. The drive got "stuck" twice during the two years I had it. Each time I blew out dust and checps that had fouled the shaft and spring, and the drive was fine. Take off your cover and clean things out, add a bit of lube to the shaft, and see if that doesn't cure your issue. I was very happy to be rid of that Reeves.
...situation years ago on my little General 160VS and an old Delta 700. Spray the shaft at the pulley with WD 40 for your first attempt to break it loose, and after that you're on your own!
Been there done that also. Don't use WD-40 it sort of lubes at first but gums things up later. Use a penetrating oil. If you have the skills take things apart and clean them. Then apply a fine quality grease to the moving parts. The big spring is really strong so be careful if you take it apart.
If you use the penetrating oil tap on the parts to create vibrations to see if you can get the penetrant to, well penetrate. You might try running the lathe after you let the penetrant do it's thing for a while. You might get lucky and it will free itself. Just move the speed lever back and forth without forcing it too much and see what that does.
If you do get it freed without having to take it apart. Wipe everything down to keep dust from sticking to all the parts.
I had this happen two times. The first time I simply removed the cover and blew out all the dust from the pulley assembly which fixed the problem. The second time I replaced the worn belt and never had the problem again. Send me an email if you want the document I used. Just remember, don't force anything.
I had the same problem on a Jet 1440 several years ago. I am surprised that people had success with WD40 or Penetrating oil. The tech rep told me to never go that route. He suggested Powdered Graphite. I bought some at the auto parts store. It was nasty putting on, but it worked past when I sold the lathe.
Lan what I usually suggest is penetrating oil to free it up. Dissassemble and then use powdered graphite to coat all the pieces that rub. I didn't have any when I took my Delta apart and used white lithium grease. Rub it on and then wipe it off with my fingers so there is a very thin layer left. It seemed to work and didn't seem to collect too much dust.
I did the same for my Dad's shopsmith. Again he has some grease and didn't have any graphite so I used what i had. It's still working fine and that was a year ago.
Well, my friends thank you all for your replies and i am sorry that I had not replied back sooner. We have some family issues that took precedence over this matter. well, last night after I took shower and cleaned up going to bed it just hit me that go back to the shop and try this method I thought I got nothing to lose now at this point. Well, for future reference for other guys that may run into this problem here is what has worked.
I first spray it with WD40., although, some of you guys warned me against that. then I picked up a small furniture makers hammer that the front is little blunt (this hammer has been around I guess about 45+ yrs (inherited from my Dad and it has made it from Iran back to US, way back in late 70's) (it may have a magical power to it); and put it gently between the opening of the larger pulley on the back of the headstock, then with a rubber mallet I gave it a quick whack on the back on the furniture hammer into the middle of this stuck pulley. and, wallah, that did the trick. It unjammed it and pulley start moving towards the headstock when I turned the speed lever to the higher speed. Now, this is my frustration. although that I routinely, blew the saw dust and cleaned off around the headstock assembly in and around this pulley and the reeves system, and I have been spraying white lithium grease on it, it still gets stuck, now I like to ask that what's the best lubrication to spray on this shaft so it won't get stuck again? I do have regular oil and high temp. grease, and graphite (which I don't like the mess it makes) on hand and I can put any of them on this shaft, however, I am hoping that some of you who have more experience in restoring tools and mechanical stuff would shed some light on this subject.
Thanks every one who took time to help out with this issue, very much appreciate it.
The Reeves drive on my Sears Craftsman Professional lathe used to drive me nuts. I had to take it apart at least every three months to free up the pulleys. I went through all the lubricants, except graphite, and everything I used would gunk up. (Heck, it was gunked up fresh out of the box. I had to take it apart to get it to work the first time.)
So, last time I had it apart, I decided not to use any lubricant at all. Bare metal to bare metal, by gracious. That was mid 2007. Have not had a problem with it since. But, . . . I did buy a PM 3520B early in 2008.
The metal against metal movement of the pulley on the shaft is only a fraction of an inch, very slow, and happens only while you are changing the speed. There will be no build up of heat, nor excessive wear, because of the limited movement.
Now I try to remember to turn it on at least twice a year and run the drive over the range of speeds. Still works. Come to think of it, I think I"m due to turn it on again.
... on my old J-line 12-36 lathe. We also had Reeves drive on our horizontal mortiser. I guess they are susceptible, but a lot depends on the housing -- whether it keeps dust and stuff out.
Doc, I tried to follow manf. suggestion to lube the shaft as they said, evidently they have no clue as for what they are talking about since they don't really use the darn thing to begin with. And, also, when I talked to the tech support the guy kept saying that there should be a spring clip behind the pulley and the reeves bracket and I kept telling him that in order to have spring clip retaining the pulley to travel along the darn shaft there need to be a little grove so the clip wouldn't go all over the place. Oh, well, see I think us users can design better stuff that those smarties(engineers) that never put what they design to test themselves to actually see if their designs make any sense in actual use. Of course no disrespect to those of you who are/were engineers. Just my feelings, because when you even call their tech support the poor guy has to know answers to all the tools, and chances are that he is not using/have used all those tools he has to give advise on. that's not possible, so I think the best answers come from users and I am glad that at least i can ask and get answers this way than 25 years ago which we didn't have access to the Internet like we do today.
