Coring with Oneway system
Aage Rendalen
Aage Rendalen
I have ordered the Oneway coring system, with their smallest, 9" knife. Question: will I be able to cut out blanks smaller than the inches indicated, in this case 9"?
Re: Coring with Oneway system
Get the new American woodturner, February issue. Should be in the stores shortly if not already. There is an excellent article on coring and figuring out the angles for entry for different bowls.
Dale Bonertz
Short answer is yes but your range is limited do to the fixed point.
robo hippy
With the Oneway, you are a bit limited by coring choices. For one, since it is on a plate rather than on the banjo, you have limited sideways movement. With the support finger, which makes it so stable no matter how far out you reach, you have a lot of metal in the kerf/cut. If you move much off center, the whole set up can bind a bit in the cut, but you can move it (pivot post) some and open up the kerf. You can move the set up back a bit farther off the headstock and take a shallower core. Depends on the piece of wood.
I am curious. You have the '9' inch blade? I think they size them by the radius of the curve, and the 9 inch blade would be the big one, and I think the 6 inch one is the small.
You can do more with one McNaughton blade than you can with one Oneway blade. But, you have to learn to aim and steer.
robo hippy
Steve Kubien
Steve Kubien
The 9" blade refers to diameter, not radius.
Yes, you can take smaller cores but they will be shallow. For example, I often take 6-7" cores with that knife but they are only 2-ish" deep.
Aage Rendalen
Steve, that's what I was hoping
Aage Rendalen
Thanks for all of your comments. Each coring system has its advantages and disadvantages. If I end up doing a lot of coring, I might eventually add the Kelton system. When the lottery comes in.
