Quick Sander thing I made today
Steven Antonucci
Steven Antonucci
I think I've seen a variety of these type ofthings in the past, and I finally got around to making one of my own. It is a hard core sander for contouring small parts on the lathe.
It consists of two end plugs turned to fit a length of Schedule 40 PVC pipe. The drive side sits in a standard chuck, and the tailstock has a center hole to put a 60 degree cone into it for better support. Variable speed at the headstock to avoid burning by sanding too fast. Paper is self-adhesive, and sticks well, but peels off for easy replacing. 120/180/400 left to right. Took 10 minutes to build.
Re: Quick Sander thing I made today
Looks good, Steve...
GaryG in MD
I've been meaning to make one of those.
Thanks for the reminder.
Do you overlap the sticky paper or leave a small gap?
(I know, you cut it with precision so there's no gap!)
Any problems at the join?
What's your source of paper? ...GG
Steven Antonucci
No overlap
Steven Antonucci
I tried to cut it with precision, but there is a gap around 1/32". I think the paper is called Carborundum- and I buy it at Totally Turning.
I do a pretty good job pushing the paper down to get it to adhere with no wrinkles or bubbles, because any lumps make a ticking sound when you use it. I plan on getting some other diameters and making a couple more of them for an idea I have.
No glue on the caps... just a press fit.
Steve
Craig Daymon
Nice.
Have you considered a buffer using a paint roller to replace the PVC? I picked up the rollers a while back, but haven't completed the project.
Steven Antonucci
No, I made my buffers already
Steven Antonucci
Old fitted sheets on a spigot, held in the chuck. Cut them "pretty round" and then turn the speed up and make them round with a skew, toe down. Little bit of a mess, with the threads floating around, but you get 5-6 buffing wheels out of a sheet. (and I have a bunch of them laying around.)
Steve
Re: No, I made my buffers already
Roy
Oddly enough I made one of these yesterday to sand the inside of Koa bracelets I made for my wife. I was to cheap to buy them for her while in Hawaii and mine came out just as nice. I mounted mine much the same as you did but removed the tail stock to allow me to sand through the 5 grits. The outside of the bracelets were sanded on a jam chuck.
