Broken earring stand repair
I was putting my turnings in our instant gallery last night and picked my earring stand up by the finial. It came off and the stand bounced off the floor and broke. First thing, and I know better but did it anyway, don't glue cross grain joints with CA. It won't hold. This tenon fit good and should have been a good glue joint. I always use epoxy on my mirrors but thought this would work. It didn't.
Follow the sequence of photos and you can see how I repaired it.
The first thing I did was put a homemade adaptor in my Nova chuck that has a 3/8" tenon. This fit in the top of the earring stand. I put the bottom in a 3/4" 4 prong drive center. I marked the center as careful as possible but didn't get it dead on.
Since the bottom wasn't aligned perfectly I turn away the bottom to the 3/4" tenon. I couldn't round the walnut part because it was off center so I slowed the lathe down and used sandpaper on a stick to round the edge as the lathe moved the part. This worked perfectly.
Then I mounted the bottom back on the lathe and turned away the torn part and redrilled the hole for the tenon. Then I put glue on everything and used the homemade Nova adapter to clamp everything together.
A little sanding and some finish and it's repaired.
Re: Broken earring stand repair
Randy Gleckler
Nice repair John, thanks for the pics showing as well. Have to keep that in the memory.
Craig Daymon
Here's hoping no one says, "Show me the earring stand facts!" before they buy it.
