Re: so how do you redrill an accurate hole later?
Dale Miner
Unless your needs require getting the blank dry enough as soon as possible, I would leave the blank undrilled. If there is figure in the wood, and the blank drys with a curve or kink, when redrilling, the bit will follow the previous no longer straight hole. If the blank is straight grained, then drilling to speed up the process is OK.
Depending on the wood, two years is generally enough for a pepper mill blank. There will be perhaps another 1% shrinkage after the the blank is turned, but for practical purposes, it will not matter. Just make sure to fit the knob tennon on the loose side with wood that is less than completly seasoned. Woods that fall into the 2 year class are maple, walnut, and cherry. Oak, hickory, hedge, and locust need a longer drying period. I've never predrilled, but have pre rounded. My guess is that predrilling would cut the drying time in half.
