nova dvr xp
Darrin Hill
WHen you turn on your nova, there is an auto default speed of 500...
Is there any way to change that? I read the manual and the latin is greek to me... (liberal arts major)..
I started a piece of elm today and it seemed that the torque was a little soft, cause my piece was cut with a chainsaw and had corners, and when it hit a corner it seemed to want to slow and not hit as hard... usually when i hit a corner it hits with a certain amount of 'whack'.. tonight it was more of a dull thud.. and i usually start at around 100-125 rpms just to rough out the corners..
it also took its time slowing down whenever it did catch.. i'm not sure how it works, but if you get a dig you can somemtimes stop the spindle and when you let go all that pent up force has to go somewhere... so it can go from a speed of 100 to 400 as it unwinds, but it slows back down to the 100... not sure how or why that works, but...
but when i did catch, it went up to 400 and took its time slowing back down to normal. It might have been because the piece is out of balance, but im a photographer, not an engineer..
so i unplugged, and took off the control cover and blew a bunch of dust out... i put it back on, plugged it in and turned it on and the auto speed was now 110 instead of the 500.. i might have accidentally changed it if its possible to do so because i was wondering if there was a mode for changing the amount of torque,.. so i pushed mode ... i think that was all i pushed...
and the manual said if you pushed mode while running it would do a diagnostic... and mine didnt do anything..
so then i came in and tried to read the manual online and it didn't seem to cover my issue.. i went back outside.. increased speed to about 250 and everything seems happy now... forgot to check the default speed after i turned it off...
just wondering..
i'd call teknatool but its saturday and they have the worst customer service anyway... so I'm just going 'hmmm'....
), r-r-r-r-r-r-r, knowing it's difficult to describe without sound. I wonder if this is common with motors of this type. Emailed Teknatool twice, never received a response, Fl and NZ both. Watched as many videos as I could find with the XP, turned up the sound, could "almost" hear some kind of sound but, couldn't determine if it was the same. Other than this little annoyance, I wouldn't trade my XP for anything.
