I just notice that my Jet 1642 generates different vibration at different speed. I am running the test with head stock clamped down securely and with nothing attached to the spindle.
When I run it at the low speed range, the vibration is very noticeable at about 1000 RPM. The vibration will go away when I reduce the speed to around 900 or increase to speed to 1100. The vibration can be felt when I lay my hand on top of the head stock and I can hear it coming.
When I run it at the high speed belt position, the worst vibration occurs at the very high end. Over the entire range, some speed will generate more vibration than other.
In a no-load condition, I expect the lathe to run smoothly across the entire speed range. If you have a Jet 1642, I would appreciate your sharing of your experience or insight on why this is happening.
Mine does the same thing and has since new. Another club member had the same problem with his 1642 and he replaced the original jet belt with a treadmill belt and had a big reduction in vibration.
I did not notice the vibration when my lathe is new. It is possible that I was not as observant then. Changing the belt on a Jet 1642 is not a simple task.
I am going to call Jet CS on Monday to see whether they know about this issue and whether there is solution.
When I once asked about this phenomenon with variable speed motors, one of my colleagues (who is a mechanical engineer) told me that every motor has a specific speed in which internal harmonic vibrations are set up that causes characteristic vibration of the device. Increase or decrease of the motor speed above or below the harmonic-generating speed that results in the elimination of the "problem" is indicative of harmonic vibration. There's not much you can do for this (as far as I know) other than adjusting the motor speed to avoid that speed. Maybe a mechanical engineer can weigh-in on this with more detail?
I doubt changing the belt will have much of an effect on altering the motor's harmonic vibration point. Try running the motor alone (without the Poly-V belt connected to the lower (motor) pulleys [hold the belt out of the way with some tape to allow the motor to spin freely without driving the spindle], and see if the vibration behavior continues as you slowly increase or decrease the motor speed. If the vibration is still there without driving the spindle, you can be pretty sure it's isolated to the motor (or motor mounts), so changing the belt likely will not diminish the vibration. You may have to live with this small amount of vibration at those particular speeds. I wouldn't start changing belts, etc. until I first determined and isolated the source of the vibration.
I've used the Jet 1642 for many years without a problem, and once in a while (i.e. with certain chuck/blank combinations) I get a bit more vibration than "normal" (whatever that is...). Just turn the speed control a bit, and keep on turning......SAFELY!
If you want to try and move that point, do some reading on a mass damper. My friend added a mass to his drill press, runs smooth as silk. Grab the mass, and the drill press starts to buzz. Included a link to an older discussion
Motors will have vibration at various speeds but what you might need to do it adjust the level of the lathe. If every foot doesn't have equal pressure you can get vibration amplified from what ever the original source.
The first thing I do is level the lathe front to back and left to right. Then you can go around the lathe and move the leveling nuts about 1/2 turn back and forth and feel the difference. You may find that one is easier to move than the others. try to make it equal by loosening it until it feels about the same.
My lathe is level with all four legs firmly on the floor. I think the problem is harmonic vibration as it only happens at certain speed. Otherwise than that, the lathe is running fine.
Yep that's it harmonics, every thing on the planet has a frequency at which it likes to vibrate, just tweak the speed knob a little and it SHOULD go away (hopefully !!!)
