Softening epoxy to realign
Craig Daymon
I turned a prayer wheel recently. Unfortunately, I epoxied in the steel shaft and failed to insure it was perpendicular to the lid into which it was glued. I'm wondering if I can somehow temporarily soften the epoxy so it can be realigned.
I'm considering a short coil of nichrome wire around the shaft, heated using my woodburner (for which I have a handle that will take wire).
I should have closed the box, which would have insured alignment without impacting the curing.
There is a rare earth magnet in the handle below the bronze bearing that holds the shaft in place when it is all together. Getting this aligned would allow the lid to close properly.
Woods are Irkok(maybe), Masur Birch and Ebony, maybe African Blackwood.
Thanks for any help,
Craig
Well now that I think about I'm pretty good at hitting sandtraps and water hazards. I can also hit the only tree in the fairway, 200 yards away and it's only 8" in diameter. I guess I am a pretty good shot with a golf club after all.
