Interesting Italian(?) Jumbo Jaws - shop made *LINK*
Craig Daymon
I checked out John Lucas' video on the Osprey tool and there was another woodturning link, I think from Italy. It appears to be a woodturning class with several turners and lathes.
The very interesting thing for me were their method for holding a bowl on the lathe to turn the bottom. It was a large disk, maybe MDF, with 3 pieces of T-track, probably positioned using T-nuts with wingnuts on the back side. On the end of each T-track was mounted an in-line skate wheel.
Basically, this is a steady rest with no pass-through hole.
I would think this would work almost like a safety center, such that if you got a catch, the bowl would spin.
About 2 minutes, 15 seconds into the video.
Anyway, looked interesting. Wondering if anyone has done this.
-Craig
Interesting jig to hold bowls for turning bottom
Re: Interesting Italian(?) Jumbo Jaws - shop made *LINK*
Jeff Willaford
Looks like a basic, shop made steady rest to me. A circle of MDF (?) with three adjustable arms with skate wheels. Used to steady the hollowform he's working on. Then maybe you saw something I didn't.
Craig Daymon
I'll have to look again. I thought he was using it to hold an inverted bowl to finish the bottom.
Dick Hines
Dick Hines
I am with Jeff on that. Basic home made steady rest.
But I got kind of dizzy watching the video. Some one should tell those guys how to pan the camera ......SLOWY.
Dick Hines
Dick Hines
Sorry....slowly
My mistake, steady rest, but...
Craig Daymon
I think the question remains if this configuration, minus the hole in the middle, would work to hold a bowl for finish turning the base. Unlike jumbo jaws, it would not be restricted to where the buttons could be located (though that is rarely an issue). Also, if you did have a catch, it should work like a safety center and allow the bowl to spin in place (momentarily), minimizing the impact.
Thoughts?
Re: My mistake, steady rest, but...
Harry B. Pye
The vessel is smaller at the chuck end. So the wheels serve to steady it, not hold it in place. If it were not for the chuck, you could pull the piece out. With the jumbo or Cole jaws, you get an interference fit.
Craig Daymon
Maybe, but that is not how you would use what I'm trying to describe.
The bowl would be placed on it with the mouth facing the headstock. The wheels would be brought up to secure the rim. The foot of the bowl would (naturally, as it is the only practical way to turn the foot) is facing the tailstock. Same configuration as jumbo jaws, but the wheels serve as the buttons. Their ability to rotate allows the piece to turn, albeit not always easily, against the underlying disk should a catch occur.
Besides, even with hollowforms, a steady rest does not require that the base of the turning be smaller than the top. For example, here's 3 vases with differing shapes, all of which would benefit from a steady rest if turned in wood.
-Craig
Lloyd in Mississauga
The steady rest could be used to help support the vessel to finish off the bottom, but you would need to try and fasten the top to the spindle in some way as the steady rest generally will not hold the piece into the head stock.
You could make wooden jaws for your chuck to hold the top, and then use the steady rest to provide support for the length. Do not turn the speed up too high, and then you could work on the base.
Lloyd
No, not using a steady rest
Craig Daymon
What I am trying to describe has the same, or similar, configuration for the skate wheels as the steady rest used in the video. (Or most shop made steady rests.) With the arms attached to a SOLID DISK. No hole. Used with out flowing bowls. (Your standard bowl, no in-turned lip.)
The wheels would be brought up snug against the bowl edge in the same way that the buttons on jumbo jaws are brought up next to the bowl rim. Difference being that if you got a catch with this configuration, the likelihood is that the bowl would spin (probably with some minor resistance), minimizing the impact of the catch.
