ukibori to the rescue...
GaryG in MD
A while back, I turned a blatant knockoff copy of a suspended Jacob Weissflog box in soft maple (just for my own pleasure, of course) and, while jam chucking the base, dented it with too much pressure. VQOFL! (see below if you don't know that one.) I had worked VERY hard to get that curve just right! No way would it go back on the lathe. (I'd have to build a tiny, ad hoc donut chuck. Ain't gonna happen!) Sanding out the dent would totally ruin the curve, not to mention being a major PITA.
So it sat on my workbench of shame for many months. It was the act of recently showing it to fellow WC member Chuck Engstrom that decided me to raise it's priority and FIX it! I even got out the sandpaper. But I couldn't do it that way. Too painful.
Then I remembered a demo I saw last year by Mike Hosaluk in which he showed how to do ukibori. The thought crossed my mind: "I'm saved!" BUT, I recognized immediately that it depended on whether the dent was actually a true compression or a removal of material caused by a slipping chuck.
Only one way to find out. I took it to a faucet and ran some water on it -- a couple times -- and set it aside to dry.
OK, it's dry. Would you believe?...
With the exception of a little surface blemish that was trivial to sand out, the curve was perfect! Not raised, and not depressed. Nor was I any more.
So, next time you get an unwanted compression dent, just throw a little water on it, and you'll be in good shape. Literally!
A lesson well learned, GG
Oh yeah, VQOFL = vast quantities of foul language
