donut chuck
Darrin Hill
going to try to make one this week... i have a nova dvr.. so i can make one up to about 15 1/2 inches...
would you make one out of oak plywood or should i use solid lumber?
d
donut chuck
Darrin Hill
d
Re: donut chuck
Bernie Weishapl
I made mine for my DVR out of scrap 3/4" plywood. On the donut side I made several of them in different sizes. So I can do bowls from 6" to 15". I think I made the openings 6", 8", 10", 12" and 14". I clamped them all together and drilled my holes. I use 4 screws on it of different lengths.
Re: donut chuck
Jim Sebring
Neither. Solid wood will expand and contract over time, depending on the humidity, and that will affect how true the disk runs.
I have the same lathe and made my donut chuck out of 3/4 inch baltic birch plywood for the headstock end. I used a 3 1/2 Don Pencil aluminum inch faceplate. I made the clamping pieces from 1/4 inch baltic birch ply. I have several of the clamping pieces made, with holes one inch apart in size. They range from 4 inches to 8 inches. I lined the holes with thin toolbox liner available from Harbor Freight. That provides a firm grip but does not mark the bowl. The baltic birch plywood is very stable - I built my chuck in 2009 and it still runs true.
Re: donut chuck
Doc Green
Darrin,
I think any good plywood 3/4" thick will serve your purpose. Or, if you have MDF handy (medium density fiberboard), that will work as well. I would not use solid lumber because at the diameter you mentioned, there is a possibility it could split (if only 3/4" thick), and that would not be good. ~Doc
Re: donut chuck
I use plywood. I turn a rebate for my standard chuck jaws so it's quick to mount and dismount. I made several different Doughnut's with various holes but all the same size as my original disc. I hold it all together with all thread rod. I used nuts and wing nuts so I can adjust the length of the rods. The can stick out the backside about 5" before hitting my headstock so it gives quite a bit of adjustability. I also have a 1" hole in the center. This holds 4" round extension pieces that have a 1" tenon. These are used for bark edge bowls that can't be clamped against the face of the plywood.
Re: donut chuck
Bill Howatt
I used 1/2" ply (construction grade) and MDF. I also have the part that clamps the bowl to the driven portion made out of 3/8" MDF.
From the above you can guess that I have different sizes available. I used 4 1/4"-20 carriage bolts with wing nuts and have them in various lengths. The carriage bolt makes a relatively smooth surface at the operator end which minimizes flesh damage - be sure the long parts stick out toward the headstock.
For normal operation the chuck really doesn't have to be all that robust since you are holding almost finished objects which are light-weight.
My main one has a fairly large plate permanently fastened to a cheap faceplate. After mounting and truing I spun it and drew a bunch of circles on it roughly 1/2" or so apart to aid in positioning. I have holes drilled in it to match the varous outer parts of the donut that I have.
Bill
Re: donut chuck
Bob Macgregor
Mine is similar. I found that the holes I drilled were concentric, but not quite evenly spaced. This meant I had to mark each mounting ring with an alignment line...sort of like numbering scroll chuck jaws... to be sure the bolts went in all the holes just right.
