Cleaning the leather strop
I've been trying to do some research on cleaning the leather strop on my Sheppac wet wheel grinder. It's getting pretty nasty looking. It still works but seems to me that you should clean some of the swarf off every now and then. What I'm finding online is all about the flat razor blade strops and a few answers for people using the Tormek for carving tools. As you might imagine the answers are all over the board from I never clean it to people who use sandpaper to clean it.
I think the sandpaper is out, I don't want to put any stray grit on my leather. What seems to lead the pack for me is sort of scraping it off with the back of a hacksaw blade and then possibly cleaning it further with a 3M abrasive pad or one of the Green pads that always come on my sponges. Some suggested that wiping with the green pad or sandpaper tended to raise the leather fibers and make them take the abrasive better. Makes sense but again not sure it's necessary.
Any one have suggestions or concerns one way or the other.
Re: Cleaning the leather strop
Steven Antonucci
I use a card scraper
Rob Wallace
Rob Wallace
I agree with Steve that scraping is the way to go. Don't use abrasives.
I would take a brand new, heavy-duty razor knife blade (the double end kind) and scrape the leather surface gently IN DRAGGING MODE, without catching the edge into the leather, and slowly raise the angle of the blade until it just begins to scrape. Clean off the adhering stuff on the leather gently by passing the cutting edge of the blade across the surface (or vice versa if powered) . If it is a new blade, it should have an even, sharp edge that will not take much pressure to scrape away the debris.
I have cleaned a used barber strop in this manner which is what I sometimes use to stop carving tools when it is laid flat on a bench.
Good luck,
Rob
Harry Robinette
Harry Robinette
I've only used a card scraper on my Jet power strop. I also just lightly oil and use yellow stone compound and not any of the real grease compounds seams to do a finer polish on my tools.
I'll try the card scraper or razor blade tomorrow. The back of the saw blade didn't work very well but then it was not very sharp.
Razor blade worked
I used a razor from my razor knife. It's thick and has single edge. I used one that came out of the knife and was used. It worked quite fine. Just lifted it up until I found the sweet angle that started lifting the gunk off the leather.
Rob Wallace
Re: Razor blade worked
Rob Wallace
Glad it worked John, and that the job is done. I paid $2 for a genuine barber strop being sold at a garage sale, and once I scraped it and cleaned it up, it has been an excellent finishing tool for stropping carving tools.
I had the same experience cleaning band saw tires after resinous wood is cut. A few quick swipes with the razor knife blade, a quick rinse with mineral spirits, and I was back in business. (If anyone tries this it is NOT done while the saw is under power - turn the wheels by hand only, and scrape in a dragging position only.)
Cheers,
Rob
The old time razor strop used.........
JamieDonaldson
...by barbers on straight razors had compound treated leather on one side and fine crocus cloth on the other. I used this combination when sharpening scalpels in my pre-med days, and still find crocus cloth to be outstanding for finishing scary sharp edged tools of all kinds.
