3520B tailstock cylinder is hardly crankable
Aage Rendalen
Aage Rendalen
I noticed today that I had to use considerable force to retract or advance my PM tailstock cylinder. Would that be the thread or gunk causing the problem? On a previous Jet 1242 I had to replace the cylinder twice because of busted threads.
Re: 3520B tailstock cylinder is hardly crankable
Josh Bowman
1st check the lock is off. I'm sure you did.
2nd check that the groove that the lock rides in is still aligned with the lock and the cylinder is not rotated. (don't ask how I know that)
3rd take it apart and clean the tailstock thread and check for nicks in the thread. File away any nicks.
Aage Rendalen
Found a message inside tailstock assembly
Aage Rendalen
When I opened up the assembly, there was a message asking where the heck I had been the seven years I've had it. Apparently you're supposed to break down and clean stuff from time to time. Once I had done that, the cylinder swiveled happily in both directions.
Pete in Holland, MI
Don't forget to grease/oil those threads one in a while too ! I do mine, along with any other lock/threaded/sliding/spinning portion of my lathe about once per year with some oil. Yup, oil draws dust, but oil/grease prevents wear too !
Pete
Normally I can spin my handwheel and let go and it keeps on spinning for a short while. When it gets to where it won't do that I take it apart and clean everything. I wipe down the guts of the Banjo more frequently than that and wipe down the lathe ways at least every few days.
Hal Taylor
I had read somewhere that drilling holes with a lot of applied force may cause this. Any experience with this? Mine can get a little stiff at times especially at the beginning of the advance but the it smoothest out.
I have heard of people wearing down the thread by cranking really hard on the tailstock but only 1 time that I know of. I do that a lot both drilling and seating the drive center by cranking the tailstock. Mine is about 8 or 9 years old now and no problems. I have a 3520A. I do 't know if the B series are any different but I suppose internal parts could be changed when the companies find new suppliers.
The new 2442 has an Acme thread which has square shoulders. It should last much longer than a tapered thread.
Mike Peace
Re: Found a message inside tailstock assembly
Mike Peace
Thanks for the thread. Mine was getting a little stiff so I took a few minutes to take it apart and clean it and it sure spins freely now. I could not fine any instructions in the manual calling for this procedure but I am more likely to notice degraded performance in the future and clean it up.
Rich Egan
I have replaced my tailstock quill once, and will probably have to do it again. You wouldn't think you can bend a thick cylnder like that, but when I removed it and rolled it on a flat surface, I could clearly see it was bent. A new quill made everything operate like new again. Now I find I have the same binding conditions again. It also causes a slight misalignment problem. The tech at Powermatic suggested taking the new parts to a machinist to have them hardened if i intend to do a lot of drilling.
