I have never used walnut oil as a finish but I purchased some 'La Tourangelle' walnut oil today. It is for human consumption and therefore no instructions as to how to apply as a finish. Any advice and help greatly appreciated.
Don I used some walnut oil a few years back that was for human consumption and never could get it to cure. I use Mahoney's or Drs Workshop walnut oil becuase it will cure especially with ambient sunlight. I flood the first coat on and keep it wet for at least 20 minutes especially the spots that soak it in pretty fast. I then wipe of the excess and let dry for 24 hrs. I will apply a second coat the next day again I flood it on. After 20 minutes I wipe the excess off. I have a south facing window which I sit them it front of and leave them for a week or two in which they are pretty well cured.
Wipe it on, let set for about 15 minutes. Wipe it off. Let set until dry and repeat until desired lustre is achieved. Food walnut oil will take longer than a heat treated oil like Mahoney's.
I use the same La T....... Haven't had any problems with it. I do allow it to dry thoroughly, and try to set it somewhere where it will get some uv, even indirect.
I buy it in a health food store, the one I like best so far comes from France, roasted walnut oil, Saveur de Terre is the brand.
I use a clean rag every time, apply with rotation motion of the hand with the lathe stopped until I am satisfied that everywhere is wet, let it sit in there 10 - 15 minutes, then turn the lathe on and raise the speed, using the same rag go all over the piece. Presto chango! you are done.
The oil is already dry and has a mellow sheen to it and a nice feel to the touch.
Do not use too much oil or it will darken the piece a bit.
Thanks, Jorge. Went to a demo yesterday and was told he uses 3 parts walnut oil with 1 part beeswax, melts it together. Ever try that? Think I'm going to start with WO only ay first, though.
I have not tried the beeswax mix, a late friend used to and once got a fire, the wax fumes are very flammable, so be very careful if you try. He did buffed the bowls in a buffing wheel after and they were quite shiny. I like them more subdue.
I use an electric skillet set on low to melt my parrafin wax. When I need to take the wax outside I use a coffee can and put wax in that. The wax in the skillet melts the wax in the can and then I can paint it on logs. I guess that's sort of a double boiler. The main thing is the heat from the skillet is far below the flash point of parrafin wax which is 480 degrees. No open flame.
I'm told buy a guy I demo'd with last year that he used the Beeswax with the Walnut oil simply because it smells good and customers comment on it, which or course helps sales. It wears off after the first time it's washed so it doesn't actually do anything for preserving the wood. Makes sense to me. I haven't tried it.
You are absolutely right Gary, big rags are a liability,
As I like to use a new clean one every time, I cut them into 4 inch squares, you can not get tangled, and I don't get close to the chuck, that area gets treated when I clean the bottom.
