Ash Platter
Ash Platter
Ash Platter
Roger Chandler
This ash platter is 15 inches in diameter........finished with one coat of Mahoney's walnut oil........my first time using this finish.......I think I am going to like it!
Re: Ash Platter
Nice!
I like the crisp bead details. A question about the finish: How fast did it dry? I haven't had a lot of luck with walnut oil drying in a reasonable time.
Re: Ash Platter
Re: Ash Platter
Terry Scott
Sweet!!!! and neat !!!
Re: Ash Platter
Re: Nice!
Roger Chandler
Thanks for taking a look Ellis........to answer your question on drying time....this was the first coat of walnut oil [Mahoney's utility] and it soaked in pretty fast and was dry to the touch in about an hour.......of course, I need to put another coat or two on it.......
It will be interesting to see how fast the second coat dries......I will put another on this morning......I hope it dries pretty quickly because I have a demo tonight and this is going to the "show & tell" for the club meeting.
Re: Ash Platter
Re: Ash Platter
Roger Chandler
Thanks Terry!
Re: Ash Platter
Re: Ash Platter
Dale Bonertz
Nice platter Roger. When you think the finish is dry put it on a paper towel and let sit overnight. If there is a ring in the morning it is not cured. It feels dry to the touch but it takes awhile to cure.
Re: Ash Platter
Re: Ash Platter
Roger Chandler
Thanks for the info Dale!
Re: Ash Platter
Re: Ash Platter
Bernie Weishapl
Great looking platter Roger. Really like the crisp details of it. I use Mahoney's or Drs Workshop walnut oil. I always use two coats. Mike Mahoney told me at a demo that ambient sunlight helps cure the oil. I always let mine cure for at least a week.
Re: Ash Platter
Re: Ash Platter
ONe of my favorite woods and you did justice.
Re: Ash Platter
Re: Ash Platter
Roger Chandler
Ash is one of my favorites as well, John........who could not like the beautiful grain, especially in a crotch piece or such.......appreciate you taking a minute to look and comment! :)
Re: Ash Platter
Re: Ash Platter
Roger Chandler
Good info Bernie........thanks!
Re: Ash Platter
Outstanding !
Re: Ash Platter
very nice Roger!
Re: Ash Platter
Re: Ash Platter
Terry Scott
Slept on this one
Had to come back for another look
Have to add that if this was Entered in the Royal Easter show and I was judging (not this year)in the platter category.She would have a nice ribbon hanging off it .
Unfortunately it could not be entered into Plain bowls or platters because the beads are seen as embellishment.But one win would be enough to make you smile
Thinks that would be looked for are no over sanding in the middle to often we see a highlighted moon in the middle that reflects the light due to a to small sanding mandrel being used and as you sand you actually sand the middle twice and as the rotation is slower takes off more wood.Your platter passes
No tear out on the beads and does the transition between beads and platter have any tool marks or sanding marks ,once again we see burn marks or shiny areas due to over sanding Your platter passes
Finish does it suit the wood and of a high standard
Your platter passes
Another area of sanding that can stand out is were the paper sands the lip of the bowl section on the tight curve .The heat build up can cause a reflective shine
To me your platter is faultless and Id like to congratulate you for the extra time and care obviously spent
Cheers
Re: Ash Platter
Re: Ash Platter
Roger Chandler
Wow.....what a review! Thank you very much for the detailed critique, Terry. The ash is the star of the show, with the nice grain pattern. Thank you for taking the time to look and comment.....much appreciated!
Re: Ash Platter
Re: very nice Roger!
Roger Chandler
thank you Mike! :)
Re: Ash Platter
Re: Outstanding !
Roger Chandler
Thank you Don! Appreciated!
Re: Ash Platter
Dale Jablonski
Re: Ash Platter
Dale Jablonski
Beautiful piece!
Re: Ash Platter
Re: Ash Platter
Roger Chandler
Thanks Dale!
