Glue up suggestions
I'm going to start making these fan type segmented mirrors again. Glue up has always been a nightmare. I use to glue them up all at once with a little jig I made with dowels and wedges. Force everything together and then drive in wedges between the dowels. It was always a nightmare, mostly because everything is wedge shaped and slippery with glue.
Last night I glued these up in pairs using the same sort of dowels with wedges and some clamps. Less hectic but very slow since I had 3 seperate glue ups.
I'd like to come up with a better way. If anyone has any ideas or techniques they've used for something like this I would appreciate seeing it.
I'm leaning toward making a jig with angle iron as a sort of frame. I'll put bolts through the angle iron so once I get all the parts inside with glue I can sort of tighten each bolt until it pushes the parts into alignment and forces them together so the glue joint is tight.
When I did my "dancing tops", I used home-built clamps of wood and small bolts and nuts to keep everything in alighment, to prevent movement.
