REAL MILK PAINT
earring stand drilling jig
I'm doing a demo on making the earring stands for our club. I realize that not every turner has a drill press so I wanted to rig up a way to drill these without a drill press. You need to have something behind the wood so the drill won't break out the back side. I turned a #2 morse taper on a 2x4. then cut out an area so the stand could fit offcenter. It works perfectly.
I had other ideas but this was very easy to do.
Re: earring stand drilling jig
Harry Robinette
Harry Robinette
I like it, quick,easy,simple and looks like it works good.
What no indexing feature?
I use the Ironfire INdex wheel.
Re: I use the Ironfire INdex wheel.
Galen Vetterick
Does that plastic index wheel stay secure with just the small bearing surface of the spindle to hold behind the chuck? I saw only one demo of a similar index wheel and it slipped on the demonstrator.
So your hole layout was made before you use your homemade drilling fixture. You always find creative ways to solve a problem or provide alternate methods.
Another wonderfully creative solution!
Steven Antonucci
I love the simplicity
Steven Antonucci
now, let's make it harder...
Since all of your stands would have to be the same height, let's make the two by four adjustable in length. A simple t-nut with a sliding dovetail should oughta do it.
We should have a Rube Goldberg contest some day to take something as simple as drilling a hole to see how much work it can be. :)
If you want to make a commercial version, the first one would cost $10,000. Second one would be $49.95...
Cool solve.
Steve
Re: I love the simplicity
Steve the photos is kind of misleading in that it looks like the base of the stand is sitting on the bottom of the cutout in the jig. It isn't. Only the lip that needs to be drilled is touching anything. So it will work with almost any height. Now width could be a problem.
I'll post a photo of this earring stand when I get it done but in my opinion the top is too wide and the bottom shape isn't very good. It needs improvement. I was building this one using segmented rings to show how that would work vs solid wood. I also wanted to try out the lower tray design and it needs work. My drawing didn't look bad but in reality it needs a lot of fine tuning.
