REAL MILK PAINT
Lathe control/switch upgrade for Woodfast
David Walser
I have a Woodfast lathe that was sold by CSUSA in the late '90s. It's controls are mounted at the headstock and I would like to move them to the tailstock. While I'm doing that, I'd like to upgrade the controls (which currently consist of a power on/off switch, a start/stop switch, and a variable speed switch) to include the ability to switch from forward to reverse. I'm doing this for two reasons: First, the power switch, which has never been too reliable, has quit working and needs to be replaced. Second, while I'm doing that, I might as well move the controls to where I'd like them and add reverse.
Questions:
1. Assuming I keep the current controls mounted where they are (if only so I don't have to mount a plate to cover up the holes), can anyone tell me which switches (with part numbers, if possible) I should buy? Everything needs to be compatible with my existing motor (Leeson 1.5hp 240v) and electronic drive (a Minarick AC100).
2. Does anyone make a kit that would make this upgrade simpler?
3. Is there any reason I shouldn't be trying to do this (other than my own lack of knowledge and competence)?
I'd appreciate any advice you might have.
Re: Lathe control/switch upgrade for Woodfast
Mike Foster
David, I still have a Woodfast sitting idle in my shop of that same vintage. (I really need to sell it as I don't envision ever needing it again).
I have worked on the controls several times over the years. I know the actual control boards are Minarik. Mine actually had a remote switch that allowed you to shut off the lathe at the tailstock end (but the speed control was still on the headstock). I can't remember the turner's name who did the engineering on it, but he passed away quite a while ago. I believe that this particular lathe was one of the first made for the general public that had variable speed. I am sure there is a better solution out there for you, but I can get the part number for the Minarik control that was used on mine if that will help. The remote switch was a low voltage switch. I can't tell you how to wire it, although I have had it open lots of times. I am no electrical engineer, but did enough to fix the controls when they took a nose dive.
Maybe someone else will have a better solution for you.
I have a similar model shortbed.....
JamieDonaldson
...Woodfast that is only 1 hp DC, and my VFD came stock with a pigtail that allowed a low voltage ON/OFF switch to be placed on the tailstock end where I wanted it. My switch is a simple rocker light switch from Lowes, and although I've replaced it once I believe the problem was dust build-up, and occasionally blowing out the box has prevented a similar problem for many years of use.
Dinyar Chavda
Like Jamie, myWoodfast came with a simple rocker light switch from Lowes, and I've replaced it often--but they're cheap at the box stores. If you want, I can send you pictures of the connections in the box.
At one time, I also thought I needed to replace the original switch, and bought a replacement, but ended up not needing it--I'll look to see if I can find where I bought it from if you want.
Finally, I was able to make my lathe go in reverse, with the help of some idiot-proof instructions from Bill Smith. If you go this route, make sure you never switch directions until the lathe has stopped turning--I usually turn it off completely before switching directions. Disconnect all power while you're working on this. Instructions are attached (I know nothing about electronics, as the attachment will attest to, but monkey-see-monkey-do worked great. Also, before you start, take pictures from various angles with your digital camera--best way to remember where that red wire really went to!)
I have to say that this worked for me, but I cannot attest to it working for you--maybe someone with more knowledge can comment. Better still, a knowledgeable local buddy can work with you on this.
marvin ewing
Thank you for the directions for reversing the Woodfast Lathe. That's the only thing on my Woodfast I have never liked.
As far as an on and off switch, if you look at the bottom of a Woodfast where the wires are, you will see a plug in that looks like a female stereo plug in. You will need to purchase a male plug in with a wire and make your own box with a magnet so it can be moved where ever you need it. The variable speed will still be at the headstock of the lathe.
Tom Tragert
Hi Mike,
I know this may be a bit off topic for this thread, but I also own a Woodfast lathe from the 90's. I recently ran across a post of yours from 2009 that provided a nice set of instructions and pictures of a vacuum adapter you made for the headstock. It seems like the perfect solution for me at this point, since none of the commercially available vacuum adapters seem like they would work very well or fit very well.
Since you mentioned that your Woodfast has been retired, would you be interested in selling the assembly you made? Let me know.
Thanks, Tom Tragert
Tom Tragert
Hi Dinyar,
Could you also send me the directions for reversing my Woodfast lathe? I've always wished it had a reverse function, but just glad someone has figured it out!
Many thanks, Tom
Dinyar Chavda
Tom:
My post above has a Word document attached to it that has the instructions.
D
