'm looking for info on turning pens. I have a Delta lathe 36" bwt centers and have done a little turning over the years on such things as chair spindles, etc. but I am by no means an accomplished turner. What I need to know is do I need a bunch of special odds and ends to fit onto my lathe . Also do I need to purchase pen blanks or is it feasable to cut them out and drill them from scratch. Not even sure I know the right questions so chime in with any advice you think might get me started in the right direction.
I just got a mandrel and a bunch of bushings from woodcraft... barrel trimmer isnt needed if u have a 90 degree sanding disk with a table and a miter gage on it. Do need some fine sandpaper... like 2000 grit.. vince's woodwonders has those...
and u can go out and cut your own.. dry it in the microwave...
I have some spalted elm, spalted pecan, regular pecan, mimosa, china berry, osage orange, a bit of walnut and a tiny bit of mesquite if u wanted to make offers... already dried and trimmed to blanks...
Although I've been turning for about 8 years, I only tried pens for the first time last week. It was a blast. I started reading the library at the International Association of Penturners. It is full of excellent info and got me up and running quickly. Great and helpful folks there with a lot of talent and willing to share.
I decided to try making a pen for the 1st time just before Xmas, as I wanted to give some out as gifts. The only net-new thing I needed was a pen mandrel (I bought the one from Woodcraft, which is working great), and the right size drill bits and bushings for my project kits. I did about 10 of them, and they all came out fine.
I cut the blanks to size on my bandsaw
For drilling the blanks, I've alternated between using a handscrew as a vice on my drill press, or drilling on the lathe with a jacobs chuck in the tailstock. I prefer the lathe at this point.
I use my disc sander with a miter gauge to sand the end of the blanks square to the tubes. Check frequently, and stop when the brass tube is consistently shiny all the way around.
Spend about a week reading the Pen forums and library at Penturners.org like Jeff suggested.
You will be much happier, have better results and more money left if you skip the pen mandrel and go directly to “turning between centers” using a 60 degree drive and live centers. Skip the barrel trimmer and get a 28 piece set of Harbor freight transfer punches to use your lath as a disc sander.
I would also suggest starting with the Sierra pen kits, Wall St II from Wood Craft but much less expensive as Sierra’s from http://www.exoticblanks.com ) they are a single tube kit and perfect for beginners. Get extra tubes for each type of kit you get as you will blow some up ;-)
You have gotten some great replies above.I concur with reading anything you can on IAP.
I stop there everyday after WoodCentral.
I also second the idea of Turning Between centers.There is a gentleman who makes cnc'd bushings that fit between your live center and dead center,they are more expensive but they eliminate the need for a mandrel,
eliminate out of round problems from a mandrel and cheaper bushings,it is easier to apply finish to your blanks as well.They can be found at Penturners Products
Using transfer punches and a disc sander with a quick jig eliminates the need for a barrel trimmer and does a better job in my opinion.
I have been making pens for about 3 years now and I can look back at some of the things I wish I had not purchased and applied the money to other items.
I truly enjoy the hobby of penmaking it has consumed most all of my woodworking since I first plugged the lathe in.
Single tube pen kits are a great way to start as Jim mentioned above.Exotic Blanks is a great supplier to deal with for many,many things.Ed and Dawn are knowledgable,willing to share ,respond very quickly to emails,willing to take time to answer questions on the phone,etc.They also include a freebie with every order,which makes it fun to see what you get.
A suggestion I may make is LeRoi Pen Kit .The LeRoi is very similar to a Sierra pen,bushings,drill bits the same,etc.
The difference is the pen transmission is twisted/activated from the finial not from the entire body of the pen having to twist to extend/retract the refill.What happens on the Sierra is the transmission begins to unscrew and your customers bring you back a pen in two parts.It is easy to re assemble but it is an annoyance that can be avoided with a different kit.
As far as blanks go any wood is just fine. I usually start with 3/4" x 3/4" x 5" blanks and go from there.
The world of acrylics,castings,inclusions,stabilizing,dyeing can take off from there.
Doug email me your mailing info and I will put together a small box of some pen kits to give you a selection to try from.
The link below is to my website and has a gallery of some of my pens.
I made a video that shows step by step of how I turned a TruStone rollerball pen.
The techniques may be a little different and more involved than what you may see others using, but it might give you some ideas you can use in your own shop.
Nice job on the video. Thanks to all for the info. I have to stuy about this before I decide to take it up as I don't like to start something and just do a few and then drop it.
Oh, and as I mentioned, you can turn pens without going through as many steps as I do in the video. That was for a reasonably high end pen, made from challenging material. People can get started with much simpler projects... but this gives you an idea of just one approach.
