Wood gloat
Wood gloat
Wood gloat
I don't usually have much to gloat about, but I just picked up a couple maple log sections that are curly and spalted. I figure it's about a ton of wood in all. I needed to use my winch to get the larger section off my buddy's trailer. I sawed this little board off the edge of one section. I hope it is indicative of what I'm going to find. We'll see.
Cheers,
Re: Wood gloat
Re: Wood gloat
clay foster
You'll need to prime that spalting before you paint it or it might bleed through.
Re: Wood gloat
Re: Wood gloat
Dick Hines
Re: Wood gloat
Dick Hines
JACK POT!!!
Nice haul Ellis
Re: Wood gloat
Steven Antonucci
Very cool... but a question?
Steven Antonucci
First, I think I've stated my undying love for curly maple before, so I'm drooling over your logs.
However, I noticed from your picture that the curl appears to "disappear" in the spalted part? Is that a camera angle thing, or does spalting somehow dimish the curl?
Steve
Re: Wood gloat
Looks like a lightning strike tree..
Dick Coers
Those irregular growths, running up the sides, are healed lightning injuries. I've harvested trees like that, and have had trouble drying the wood. The lignin must get kinda fried, because they don't like to stay together when drying. Don't get me wrong, there is usually lots of good wood in there, but be cautious if trying to turn large blanks. You'll get the most solid wood in that curly sapwood, and it makes you sick not to be able to use all those colors. Hope I'm wrong, but I've done that a few times.
Re: Wood gloat
It will vary
The curl is in the spalt, too, but not necessarily in all the wood. The sample I posted was from the base of the tree, where the curl is greatest. I expect all kinds of variations as I open up these logs. There are a couple crotches there, too that should prove interesting.
C'mon over and grab a piece.
Re: Wood gloat
I agree
There was a blowout on one side of the log at the base where the lightning went to ground. The major spalt influence, though, was from limbs that had been chopped off earlier in the tree's history. You can see how the spalt seeped in and down the log.
I've turned three pieces so far, with more on the drawing board as I chop these things up. The first one had checks that forced me to reconsider the form, but I'll still get a nice piece out of it. I turned a hollowform last night that came out pretty nicely. I haven't reverse chucked it yet, but I will soon. Should be okay.
I'm about to be experimenting with a product called "Git Rot", which is a very thin epoxy that I think will stabilize punky sections and expand my horizons here. I'd be happy to entertain other suggestions.
Cheers,
Re: Wood gloat
Re: I agree
Dick Coers
We had a marketing guy at our pen turners gathering last year. He sells a product called Cactus Juice that works extremely well. He stabilizes stuff that is barely held together, and you can add dye as well. Curtis put on a couple demos, and had product that was really impressive. He had blocks over 2" thick that had 100% penetration of the stabilizing fluid. You need a vacuum chamber, very good pump, and a toaster oven to set the acrylic. So the wood has to be bone dry before the stabilizing, or you crack it with the heat. Send me a PM if you want the link. Google will get you there easily.
Re: Wood gloat
Brad Vietje
NICE!  Must be Norway Maple
Brad Vietje
...with that Ash-like bark pattern.
Really nice looking wood -- will be great to see your finished pieces. I had some Sugar Maple with sharply-demarcated spalting like that, and there was a large difference in shrinkage between the heavily spalted parts and the sound sapwood adjacent to it. The wood seemed to bend at the border between spalted and sound wood. I have a few hollow forms that dried quite lop-sided as a result.
Hope you have a ball turning that stuff!
Safe spinning,
Brad Vietje
Newbury, VT
PS: looks like you have almost no snow ?!?
Re: Wood gloat
Re: Wood gloat
steve worcester
Yep, use Kilz.
Re: Wood gloat
Very Pretty!
Don Orr
I love how the medullary ray flecks jump out in the spalted areas. Looking forward to the finished products.
Re: Wood gloat
Norway maple
It could very well be Norway maple. It's definitely a soft maple, and it has curl everywhere, which is very common in the Norway maple I've turned in the past.
Yeah, we've only had a couple inches of snow all winter here. We've got trees getting set to leaf out. Too bad, too. These warm winters aren't killing off various nasty bugs that have been killing off ash, walnut and oak trees.
