Reducing the finish luster from high-gloss look
Bert Bleckwenn
In finishing a Cherry Crotch platter, I applied BLO to enhance the grain and then used several coats of the water-based General Finishes Polyacrylic Satin, but ended up with a very high sheen after buffing it out. I buffed with Beal Buffing with Tripoli and White Diamond only, no wax. to achieve a smoother surface. The result actually looks more like a very high-gloss finish.
Can I resand/scuff and spray with a couple coats of Flat finish to reduce the final sheen and then re-buff, or can you only go higher in sheen? I seem to recall that you can only go one way which is to add more sheen/gloss by re-applying a higher gloss finish product. If that is the case, then I probably will have to completely sand off the current finish and start over.
Re: Reducing the finish luster from high-gloss look
Dick Coers
Just abrade what you have. Abralon pads, synthetic steel wool (Scotchbrite pads), or 0000 steel wool. I prefer the Abralon pads as the others do leave visible scratches.
Exactly what Dick said. I generally use 4/0 steel wool because I'm more comfortable with how it works but the abralon pads are good. If it looks too flat when you get done hand rub some wax into it. I use Johnson's paste wax.
Harry Robinette
Harry Robinette
Bert
Did you stir the poly real good, if it shines that means it wasn't stirred enough or you buffed it up to much.
Welcome to WC, Bert!
GaryG in MD
I also agree exactly with Dick, but, unlike John, I would use Abralon.
(I HATE steel wool!)
Abralon is what I always use for my final finish -- usually stopping at 4000, which gives just the right amount of satiny shine for my taste. ...GG
