Sharpening a skew - using a jig - like Terry Scott
Craig Daymon
Watching Terry Scott's video yesterday and one thing that really stuck (lots of good stuff in all) was the way he sharpened his skew with the Tru-Grind jig. Can this be done with a Wolverine jig? I presume it is only good for relatively small skews with a Wolverine, if at all.
Re: Sharpening a skew - using a jig - like Terry Scott
Re: Sharpening a skew - using a jig - like Terry S *LINK*
Haven't seen TErry's video but here is how I do it.
https://www.youtube.com/watch?v=MJYNLkPh_LM
Craig Daymon
Thanks John. Nice video. Though I can sharpen a skew. After all, it's probably the easiest tool to sharpen.
What I liked was the way Terry Scott sharpened it using the Tru-Grind jig and was interested if anyone had tried the method with a Wolverine/Vari-Grind setup.
no need to grind. just hone with diamond
Eventually you do have to grind.
I grind my skews with a concave bevel so that you are only honing a small contact area. However the contact area gets bigger and bigger so sooner or later you regrind the concave.
If you use a flat bevel you could hone a micro bevel but it's also going to get bigger and bigger and you eventually have to grind the whole flat area.
If you use a convex bevel you might be able to hone for a good while but you would be honing the whole bevel because if you just hone the tip is seems to me like you gradually be making the tip more round or more blunt until it would not cut correctly.
Brad Vietje
Brad Vietje
Nice video, John.
That's a very clear explanation, and a nice little jig, too. Looks like your 2" belt runs downward, but seems to work quite well.
Safe spinning,
Brad Vietje
Newbury, VT
sure but not to SHARPEN
