Back Hollowing
Back Hollowing
Back Hollowing
Jeff Rich
What is the secret?
I have tried for years, with varying degrees of success to learn and master this cut. It seems that when I think I have it figured out the tool stutters, catches and tears the wood.
I believe I am losing the bevel rubbing but cant be sure.
I have tried many different grinds and many different tools.
Does a shorter or longer bevel work better than the other?
Does tool shape affect the cut?
Maybe I am being too heavy handed with the tool.
Like the mystery of the tootsie pop....the world may never know.
Re: Back Hollowing
Joe Fleming
Re: Back Hollowing
Joe Fleming
Jeff, I use a regular 40 degree swept back grind on my spindle gouge for back cutting. The tool cuts at about 1 o'clock on the dial.
You need to drill the center out first. A properly designed spindle gouge will do this just like an old-fashioned spoon bit. What is a properly designed spindle gouge you ask? The bottom of the flute is exactly on the center line of the bar. That means the cutting tip is in the exact center of the bar and the tip can drill. Don't use too fast of a speed.
Joe Fleming - San Diego
Re: Back Hollowing
Re: Back Hollowing
don stephan
the process seems to work better for me when I remember to keep pressure on both the work at about 9 o'clock and the tool rest. But I have problems when the hollow diameter reaches about 1 1/4" - starts grabbing. Probably need a steeper side bevel angle so the bottom of the bevel doesn't block the cut.
