A friend gave me this burl many years ago. It had a huge defect in the middle that went pretty deep. I had waxed the upper surface and put it up until I could figure out what to do with it. Then it finally hit me. I wanted to turn a bowl and leave the outside completely natural. I figured out how to mount it using hot glued wedges. I think this is Oak burl but not sure.
John, Nice job; it doesn't look like Oak in my opinion; it has all the characteristics of Yellow Birch burl(as we know it here in Canada). It looks like the bark is flakey and also has a yellow/goldish tinge.
looks like white oak burl to me. I've done several dozen similar pieces. Instead of wedges, I usually mount between centers and turn a 2"-3" flat on the bottom and then glue on a waste block. a tenon on the waste block holds the piece for turning the face/bowl.
I really like working with irregular burls like this. Nice job.
I just hit them with a hammer. On smooth bowls I use a piece of thin guitar wire on handles. I pull the wire through the glue joint with a sort of sawing motion.
well I should say the first thing I do is try to peel the glue off. Sometimes it comes off some good hard tugging. When that fails I go with the wire. In this case I didn't think the wire would work and actually thought I would damage the bark anyway and have to go to plan B. Howevever the hammer worked quite well and actually left very little glue on the bark. Relieved a lot of stress while I was at it. Nothing like beating on something with a hammer to relieve stress. I think Thor the god of Thunder was actually the Psychologist of the gods.
Beautiful piece John. Thanks for the tip on using the wedges and hot glue. You are correct, nothing takes the aggression out like beating something with a hammer!
If the piece is small enough I pop it in the microwave for 30 seconds or so. The glue softens up and comes right off. Of course for a big piece a hammer may be preferred -- depending on how the day is going
Brad I worried about that and of course stayed out of the line of fire. However it's being from all directions. The hot glue holding the wedges to the board are more or less holding the bowl from flying sideways. The glue to bark is doing that as well as keeping it from popping out.
nnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm My dog typed this. She just has to stand on my keyboard for attention.
Doesnt take much, heat gun on low heat enough to soften the glue
On a burl you can have on full blast as the heat wont hurt the wood
If you want to place a large piece on the lathe with hot melt glue place on all the connection points on the holding mount .By the time you have done them all some of the glue will have hardened.Get out the hot air gun and heat all the glue so it is at a even melt .Them push the work piece into the glue.
When removing scrap off any residue when still melted then with Turps soak the glue left on the work.
If a burl you can place in the freezer and the glue just picks off
It does. That is what I use when I have to glue to a finished piece. I use the wire garret method to remove the wooden wedges, then some glue will easily peel off. the rest I remove with Alcohol.
