using an airbrush?
using an airbrush?
using an airbrush?
darrin hill
Got an airbrush from a friend of mine to play with. Tried 50/50 high gloss deft lacquer and it seems fine but i get areas of non-shiny areas.
Spraying it while on the lathe spinning at 100 rpms.. just hard to see spray while spinning but i dont get an even coat if i dont spin...
what am i not doing right?
Re: using an airbrush?
How did you prep the surface .........
JamieDonaldson
.....to be sprayed? Those dull areas are most likely where the spray was soaking into unsealed or soft surfaces, and I always well seal with thinned lacquer by wiping on by hand before any spray applications.
Re: How did you prep the surface .........
I never spray while the work is spinning. Too hard to see where the spray lines overlap. I use a good light and then use the normal spray technique for painting cars and such. Start off the piece, go across keeping the same distance from the wood all the way stopping after I pass the wood. Of course I use a larger touch up gun instead of an air brush. I use the air brush only for painting and dying the wood.
darrin hill
sanded down to 2000 grit, formbys tung oil, and then sprayed a coat, sanded, sprayed, sanded, sprayed, sanded, sprayed etc..
but i get blushes each time.. and if i spray over them, then the edges of the new spray blush..
d
darrin hill
how big is the one u use for lacquer?
Re: How did you prep the surface ......... *LINK*
Here's the one I use. I know it's not the best and I often have a slightly textured surface that I need to buff to get the gloss but I've used these for about 7 years now and it works for me. I plan to spend more time learning to get the proper dilution and/or add retarder if I need this spring to get a better spray job.
The biggest problem with this tool is the overspray. I simply have to spray outdoors. I usually stand in the door and spray outside on bad days. I use this mostly for my hand mirrors and ornaments. For other stuff I use other finishes especially during the winter when the weather is simply not good enough to spray.
http://www.harborfreight.com/touch-up-air-spray-gun-66871.html
Keith Tompkins
Keith Tompkins
Darrin, If you're getting blushing, you probably have trapped moisture under the finish...too much humidity usually causes it. Are you using water based Deft? If so, you will always have blushing before the film dries. Personally, I wouldn't use an oil finish under lacquer, if anything, a sanding sealer compatable with the topcoat. The sanding sealer will help prevent areas that absorb more finish than others. I would also not spray while the work is rotating.
Janice Manuel
I spray Deft with an airbrush regularly. I thin it with about 1/3 acetone, not lacquer thinner. The acetone evaporates so quick, it's mostly gone by the time the spray lands on your piece so you don't get runs. I usually brush on the first coat pretty thick since so much soaks in.
I'm spraying scroll saw pieces mostly, and hold them in good light where I can see how much is on the piece...reflected light is a good thing for that...
I use the biggest tip that came with my airbrush...
darrin hill
john.. how do you buff after spraying? i tried it last ngiht and it just stripped off the lacquer...
Joe Fleming
Joe Fleming
Darrin,
Sent you a couple of documents off line.
All,
Be careful using strong solvents in your airbrushes. Many brushes to not have the seals that will hold up to acetone and lacquer thinner over time. I know that Iwata makes n airbrush with appropriate seals. I presume the other makers carry models that do too. It is work checking out.
Joe Fleming - San Diego
