A55 Smoothing Plane
Microwave test
Microwave test
Microwave test
Mike Foster
Well I think my microwave test is close enough for final thoughts. I cut a couple of blocks of cherry about the same thickness as the piece I want to carve (around 3" square) and about 4 " long. I sanded all surfaces quickly in order to see any checks and duplicate what I want to dry. The end grain of one I left bare, the other I sealed with shellac (couple of coats of rattle can). They both started at 9 3/8 ounces (used a kitchen scale) and both wound up at about 7 1/8 ounces so they each lost the same weight, about 25% of their original wet weight.
There was significant checking on the end grain of the bare wood blank. Couldn't tell how deep it extended, but one check reached the outside surface, and that one went 1/2" deep. There was one very small check in the center of one side of the block sealed with shellac. I was going to take pics to show the difference, but as I neared equilibrium the checks on the bare piece started to close. Closed to the point where you can't really see them well and I'm not sure my camera would pick them up. So, just as John J said in the previous thread, if you wait and don't hit the check with CA to wedge it open, it could disappear after all drying is done.
So once I have my piece carved, I am going to hit the end grain with shellac, then just nuke it. I kept all my microwave sessions to 30-45 seconds and the wood got warm, but never hot. I may be able to speed it up by getting it hot, but don't want to risk fire, as has been discussed in several posts recently. I would do as John J suggested, stick it in a paper bag and wait, but I want to get this done quicker rather that waiting for a month or two.
Mike
Re: Microwave test
Re: Microwave test
Peter Rand
Mike - While experimenting I still wouldn't neglect boiling - you might find it better.
Re: Microwave test
Re: Microwave test
GaryG in MD
I've read a lot of good things about the results from boiling, but the one thing to consider is that it makes the surface seriously ugly to a depth of a few mm, so you have to re-turn or re-carve, or whatever, the entire surface after boiling. ...Gary
