chainsaw jig thing
chainsaw jig thing
chainsaw jig thing
darrin hill
I have a groom to be who is a welder and i asked if he might do some welding for me in trade for photos and such..
i've seen jigs to help hold logs when you're trimming them... just was wondering if anyone had a spiffy log holder or something similar...
looking for photos so i can send them to the welder guy.
Re: chainsaw jig thing
darrin hill
uummm.. not what i was remembering...
Steven Antonucci
If you mean a cutting bench, it shouldn't be metal
Steven Antonucci
I have a bench that I made out of old landscape timbers, but I don't use it as much as I used to because I'd have to move the logs to it. Main cutting helper these days is a maple stump that is relatively low because most of the wood I am cutting is pretty big, and I couldn't lift it onto the bench by myself even if I wanted to.
Main thing to consider is that you want to have only wood below the path of your chainsaw to prevent destroying the chain. All of my hardware is outside the cutting path...
Steve
I use my shavings pile
Mike Foster
I would venture to guess that most turners have a pile of shavings somewhere. I just use this to hold the wood while cutting blanks. No issues with metal or hardware, you can make a depression to fit what's being cut and no worries when you cut through the log as it is just shavings under it. Cheap and effective. I bet you have a pile pretty high right now Steve.
Steven Antonucci
My pile would be high if it wasn't in a hole
Re: chainsaw jig thing- Down & Dirty
Wayne Kuhn
My down & dirty log cradle is simply 4-2x4's a foot long each. Face glue the corners and screw them together creating a square. Then drill hole for a dowel or two in each corner, glue dowels in the holes. Once the glue cures remove the screws. You now have a consumable log cradle that will hold the largest of logs for sawing. Once you eventually cut through it send it to the firewood pile and make another.
Big logs roll right up on it and smaller ones can be lifted on a sawhorse table.
Works great for me.
Re: Log Processing Center -- "LPC"
Lee Tourtelotte
Check out our Minnesota Woodturners Association Newsletter for Sept 2012.
On Page 7 is an article on a "LPC" -- a Log Processing Center that our club volunteers built in kit form & made available at cost to our members. Our LPC design is fast, enjoyable to use & above all, very safe way of preparing bowl blanks. Pictures & description on p. 7 of our Sept 2012 newsletter.
Go to: http://www.mnwoodturners.com
Info available to anyone that asks.
Lee Tourtelotte
charlie belden
I can get myself and my chainsaw closer to the ground much more easily than getting a wet, heavy, logette up waist high. But you do want your logette up out of the dirt - just a bit. And if you can ROLL it onto something that gets it up out of the dirt, rather than LIFTING it - all the better.
You also want whatever is used to get the logette up off the dirt to be WOOD, which doesn't dull your chain nearly as fast as metal or dirt. An 8' 4x4, of pine, doug fir or redwood, four dowels and some glue and you can make a logette holder that works great for sawing things up. See the bottom of the attached image.
Re: chainsaw jig thing *LINK*
Bob Macgregor
A peavey or cant hook would work well for just rolling logs over...say you'd cut most of the way through then wanted to roll the uncut side to the top to reduce the risk of sawing dirt. The Northern Tool Timberjack just adds a foot to a cant hook so the whole log (or an end of it) can be propped up off the ground enought to saw off blocks in continuous cuts without stopping to roll the log over.
If you are just cutting rounds or blocking firewood, any of these will work fine. I get too tired of bending over, so I use a saw buck that I built a couple of years ago...it is just four X's in a line with cross-bracing to make everything stiff. As long as I cut between the X's, it should last a long time.
If you are cutting rounds to remove the pith and make bowl blanks, then you need a different support system. I could probably use my saw buck, with care, but usually just use a big block with a V notch cut across the end that's up; this holds a block steady while sawing it down through the pith. Bill Grumbine has a nice how-to on sawing bowl blanks. His technique is almost identical to mine except he doesn't bother with V-notch; he just wedges the blanks in place while he cuts through the pith.
Steve's point is a good one: don't put metal (even aluminum) in the intended [or potential] path of the chainsaw. You can saw parallel to a metal part (like a cant hook) with reasonable safety, but sawing toward metal is just asking for trouble.
BOB
http://wonderfulwood.com/sawing-a-log-for-bowls/
Joe Fleming
Joe Fleming
Lee - Its the December 2012 issue. Thanks.
