ADVERTISE HERE - FREE TRIAL
Microwave drying, prevent fire
Bob Bosworth
In a previous life I did considerable broadcast-burning in the forest. Due to high values at risk, severe public scrutiny and objectives of the projects, there was very little room for error, and burn prescriptions spell out very narrow "windows" within which to burn. Fuel moisture is a key component of the Rx. Particularly, in spring, as winter snow melts off, and fuels begin to dry out, we wanted to be ready to burn as soon as fuels were in the "window". At that time of year, the fuels are moving into the window, then thru the window, then out of the window. We could not afford to miss a window when things were in prescription. We would collect samples of twigs, branches and other woody debris and dry in a microwave until no further weight loss, to compute moisture content. Scientists at our Fire Lab recommended that a large fully wetted sponge be placed in the oven with a charge of fuels to prevent burning of the fuels. This dampens the energy in the oven as fuels approach "dry", while still allowing moisture to be released by fuels that aren't quite as dry as others in the sample. We never burned down the office, or set a fire in the oven, and we burned thousands of acres of forest land safely and within the land managers prescription. This technique can be used in drying bowls and other lathe projects.
Re: Microwave drying, prevent fire
Thanks Bob.  really cool
Dale Jablonski
Dale Jablonski
Welcome fellow firebug!
Jim Breeden
The one and only time I tried the microwave drying process I had a VERY unhappy other self >( - Never again !
Dan Jechura
Dan Jechura
I have been using the microwave for a year now with good results. I only use defrost for 3 min. Then let it cool for 1/2 hr. I can do unto 15 inch dia. I heard about not using high power because of a possible fire.
Dan J.
that sounds like a great idea.
Interesting story and information
