Lathe Height?-new to turning
Kelly Handwerk
I am new to turning and im using my dad's 1236 jet lathe-can I raise the lathe up off the ground-seems to be a little low-what's the pros and cons if I raise the lathe up? Thanks Kelly Handwerk.
Re: Lathe Height?-new to turning
Jim Barbour
Jim Barbour
Hi Kelly ~
Welcome to the world of turning. For most of us the lathe needs to be at a height that puts the line between the drive center and the tail center on a level with our elbow when we stand comfortably. With your shoulders relaxed bend your arms up to 90 degrees and the live center point should just poke you at the bottom of your elbow. The idea is that you should not have to either bend over or lift your shoulders to work. For most of us elbow height seems to be about right.
As far as adjusting the lathe height the only concern is stability. You don't want to introduce any looseness that can lead to vibration and, of course, you REALLY don't want the lathe walking off of whatever you use to lift it. It all depends on what the lathe is on now and what you plan to turn. If you are planning on natural edge bowls of some size you will be turning off balance wood at some point; if you are planning of making pens and small boxes it is not so critical. Looking to the current configuration of the lathe, if it is on four legs (as opposed to a cabinet) you can simply make two torsion boxes of the correct height and bolt the legs to to the boxes, running them perpendicular to the axis of rotation of the lathe; on the left and right, not the front and back. If it only needs an inch or so, bolting the legs to a 2X4 or 2X6 laying flat on the floor will work. I had a lathe that for several years stood on a four-legged stand which itself stood on two 4X4 "skids", one on each end. It was all bolted to the floor and seemed to work just fine.
Of course you can go all out and make a new lathe cabinet, but I suspect you have something simpler in mind.
I'm sure you will get lots of advice from others in the group -- we may have lots of different approaches to the particulars, but you will find we agree completely on the safety issues -- first it MUST be safe, then it SHOULD be comfortable.
Rob Wallace
Re: Lathe Height?-new to turning *LINK*
Rob Wallace
Hi Kelly:
I sent you an e-mail message with an attachment which has information in it to help with setting up your woodturning workstation. (from the AAW Woodturning FUNdamentals e-newsletters - Link below).
Most turners would recommend that the spindle height be within 1 inch of the distance from the floor to your elbow when your forearm is held out in front of you, parallel to the ground. For doing mostly hollowing operations, some prefer the spindle height to be about 2" higher than elbow height. See the illustration in my article for additional information. Some adjustment might be necessary to find your own personal preference, but this is a good starting point.
Rob Wallace
AAW Woodturning FUNdamentals Resources
Steve Kniffen
I have a Jet 1642. I'm 6'3. After half a day of turning, my back ached. I took an 8' 2x6, cut it into 4 pieces, bolted them into 2 pieces 2x6x3 then replaced the leveling feet with the 2x6x3 pieces. They sit perpendicular to the direction of rotation and are slightly wider than the legs of the lathe so stability has been increased. Back doesn't hurt any more either. Steve
Kelly Handwerk
Thanks Jim, Rob, and Steve I have read your recommendations and hope to get to the shop and make some adjustments. Thanks again to each of you.
Peter Charles Fagg (UK)
If my dime is worth anything?
Lathe height is decided by the physical capabilities or lack of for the turner.
There is a rule of thumb that states the height of your elbow at the centre but for awkward people like myself it is too low!
My own lathe is about 2 inches above that height so that I do not have to bend my back at all whilst turning. It suits me but visiting turners complain that it is too high and uncomfortable!
Please try using different thicknesses of blocks etc. to get the height at which you could happily spend a day turning without too much strain.
Welcome to the obsession, Peter.
Jorge
I am lathe to answer, but I have my lathe with the spindle at my nipples height, higher than the usual recommended, and I am thinking about raising it one more inch to help me keep my back nice and straight.
Kelly Handwerk
Again thanks for all of the info-I checked today with my lathe and I will need to raise my lathe 7 in. in height.
