Have a question? Ask Woody!
3520b Problem
3520b Problem
3520b Problem
Bill McWhirter
My 6 year-old 3520B has developed a problem that I have not seen discussed and I am looking for help.
When I turn it on, it may or may not start, or it may start after a 15 to 20 seconds (dangerous), or it may start after I give the spindle a spin.
Question: does the 3520 have a starting capacitor, does this sound like the problem, and, if so, is it user-replaceable?
Any suggestion would be appreciated.
Re: 3520b Problem
Leo Cuellar
Re: 3520b Problem
Leo Cuellar
Hi Bill,
My Griz had a similar problem. I found out (too late) that it was a loose screw inside the inverter box. That is where I would look first, although I'm sure you'll get a more specific answer from someone else.
Re: 3520b Problem
Re: 3520b Problem
Alan Dick
Do you have an aux. switch wired in as well as the switch on the headstock? I had a similar problem as the aux switch got dirty from shavings and dust. Replaced the switch and was good to go.
Alan
Re: 3520b Problem
Re: 3520b Problem
Bill McWhirter
That was my first thought. Removed it. Symptoms persisted.
Re: 3520b Problem
Re: 3520b Problem
Don Evans
Did you by chance get a manual with this machine? Look in it for a diagram of parts for the machine. Even if it is a drawing it may show if the motor has caps attached or list them in the parts breakdown that is with the picture.
Also a good manual will have a Troubleshooting section that gives known problems and what a user can do that may correct them.
Don
Re: 3520b Problem
Re: 3520b Problem
James Ley
The 3520B has a 3 phase motor and therefore does not have a starting capacitor. There are really only three likely possibilities for this issue, you have a faulty main start stop switch, you have an open phase on the motor or you have an open in one of the wires leading to the motor, The bad main start stop switch is most likely, can you put your secondary switch back in and bypass the main switch? If it functions properly then it is the main switch, if not I can walk you through checking the other possibilities.
Re: 3520b Problem
Re: 3520b Problem
Bill The first thing I would do is check all connections. Make sure they are solid. Take the cover off the VFD and check the connections there. I haven't had the cover off the Powermatic but other drives I've installed had the 3 wires just held in with a set screw that pushes on the wire. I have seen these loose. There should also be wires going from the VFD to the remote speed control. Check and see if those are loose.
Dirty switches are probably the #1 culprit on the powermatic. I have never had a problem with my main switch but the remote switch was a constant headache. I dissassemble and clean them but many people would probably not feel comfortable with that. Replacement would be the best bet.
Above all else I would call Powermatic. Don't know how much help they will be because I've never talked to them but it's at least a start.
Re: 3520b Problem
Don Leydens
Re: 3520b Problem
Don Leydens
Bill, I had the EXACT same problem with my 3520B. I opened the front door and just pushed all the wire connections (unplug, of coarse) to make sure they were seated firmly and then blew out the compartment very well with an air hose. Not sure which of those to areas were the problem, but it hasn't happened since (almost a year ago). I now regularly blow out that compartment and have been good to go ever since. Nice when a problem has a simple fix. :-)
Re: 3520b Problem
Re: 3520b Problem
lynn cranmer
I just had the same problem and did exactly what Don did and it solved the problem.
Re: 3520b Problem
Re: 3520b Problem
Bill McWhirter
Narrowed it down to a bad switch. Fortunately Graingers has it in their catalog for $12 or so. If I have to buy the entire pushbutton, it will be about $40. Just hope that the local store has one or the other in stock.
Incidentally, the problem started right after I blew it out. Doubt if it had anything to do with the problem, though.
Re: 3520b Problem
Re: 3520b Problem
DennisBilevich
Compress air can cause this,I had same thing happen to me years ago,I put sandwich bag over the inside so now i can blow it , this has work for years
