Waterproofing vases
Waterproofing vases
Waterproofing vases
Rick Sollie
Any suggestions on wateproofing turned flower vases with a finish that will look nice as well as protect the wood?
Re: Waterproofing vases
Thinned heated epoxy. It will penetrate better than regular epoxy and will hold up as good as anything else I think. That being said I'm not use how long any wood will hold up to any finish simply because the wood moves and damages the finish.
West system epoxies are widely used the boat industry. That should tell you something.
Dick Hines
Dick Hines
Barbara Dill uses CA to finish the inside of her coffee cups. She has one that she has used for years. At the price of CA this could be pricey
Harry Robinette
Harry Robinette
I heard or read somewhere of guy's using that rubbery stuff that goes on tool handles. I don't know for sure if it works.
Re: Waterproofing vases *LINK*
It might be hard to apply but it is waterproof. I have used the dip for handles and used the spray cans to make steel weights rubbery and waterproof back when I was teaching lifesaving. I don't know if the can stuff can be thinned but if it can it could be brushed or poured on. It's good stuff. Nasty to smell. I also used it to cover some bricks that I used to prop up artwork that I was photographing. The rubbery compound protected the artwork from damage from the bricks.
http://www.plastidip.com/
Rick Sollie
Thanks guys. All good ideas applicable to different pieces and different situations. I am also going to look into the possibility of finding a pigmented epoxy based paint that will provide the waterproofing I want and also match the visible portion of the interior to vases which are finished in various colors. Perhaps the finishes used on concrete floors will work. Will post my findings when I know more.
jim 9 miles
I have seen plastic inserts. Solves problem of wood movement etc.
