Drive problems Jet 1442
walt cheever
My Jet 1442 is about 7 years old, with a Reeves drive. I discovered that I had no torque above 1200 rpm, and when I checked the drive pulleys, found that the split pulley on the motor shaft wouldn't close all the way. A quick conversation with Jet technical support suggested that the keyway in moving half of the pulley had distorted, and I needed to replace it.
I pulled the old pulley off, and that was indeed the problem, and the replacement was fairly easy (it needed 4 hands however) and my machine works well. I learned a few things I'd like to share.
If this happens to you and you are buying new pulleys--buy a replacement shaft key as well. It's good insurance. Mine was distorted, but when I turned it over it looks like it will work. (fingers crossed.)
I had lubed the shaft with graphite, to avoid attracting dust. Tech Support said that most people who call with my problem had used graphite-they strongly recommend using oil, then cleaning out the junk yearly.
The end of the motor shaft seems to have a lube fitting in it, and there is a lube hole in the shaft that happens right under the moveable part of the pulley. The end fitting has some sort of spring mounted closure, sort of like a zerk fitting, but without the rounded part that a grease gun grabs. It would be a wonderful way to get a bit of lube right where it's needed, but I can't figure out how to get it past the closure.
I called Tech Support about that, they had no idea about what the fitting was for or how to use it. Their suggestion is to put in drops of oil with a long spouted oiler. Has anyone else figured out how to use that fitting?
Anyway--I back to turning, and pleased about it.
Re: Drive problems Jet 1442
Thanks, Walt
No help on the Zerk fitting, but thanks for bringing these issues to people's attention.
Glad you're back in business.
Ellis Walentine, Host
