Bandsaw table redo
Bandsaw table redo
Bandsaw table redo
When I bought the new table saw I had to redo where everything went in the shop and since I had to build an extension table for the saw I decided it was time to add a larger table to the bandsaw as well as improve it's dust collection. I always found it hard to handle the wood on that tiny bandsaw table. I now have a table that's almost 22x30. It was made from a table top that I salvaged from work so it had a hole for cords. I filled in the hole with a turned piece and then patched a bad area with another scrap.
I have one more flat wood project (well actually two if you count a chair repair), then I'll be able to get back to turning.
Re: Bandsaw table redo
klowwn
John, they look great! would you by chance have some plans or ideas for your bandsaw table? I have a Ridgid bandsaw that I want to make the table larger. I have a Kreg fence so I can't add much to the front, but want to add to the sides and out feed. Any suggestions on how you built and also attached it to the steel factory table? Did you use standard particle board based countertop material avail at the big boxes or did you make up your own using some other substrate material?
Thanks
Ricc Havens
Galen Vetterick
It looks real good John. If you keep expanding your working surfaces your next project will be moving the walls out to get around! :D
Ric My table had holes tapped in the 4 corners possibly to accepts some fences. I simply attached a piece of angle iron to the 2 on the front and the 2 on the back. Then I cut dado's in the top plywood so it would sit over the angle iron and be just a hair below the surface of the original table. I did elongate the holes I drilled in the angle iron so it was adjustable a little so once I got the table screwed down I just leveled each corner with the existing table.
THANKS!! - NM
Bandsaw mods-pics
Here are the pics showing the mods. The stick in the back to support the table is simply jammed in place so I can remove it when I need to tilt the table.
The dust collection pieces are all held in place with rare earth magnets. I cut some narrow pieces of steel rod and glued it in the wood and then glued a rare earth magnet opposite to hold the piece. These can easily be removed to tilt the table. There are just 3 of them if you don't count the small piece hot glued in place behind the photo to block the small gap at the left side of the blade.
I had to cut the top to insert the blade and added a metal bracket to lock these pieces together to support that part of the top.
Re: Shop tool mods
Galen Vetterick
John
I know you work steel and wood, so have you ever come close to making a drill press table add-on that works for more than just one application? I recall your jig for mirror drilling and it looked like it was on a stock table. Nothing I come up with ever seems to work for the next drilling/sanding/press application and I spend more time making something work than drill time.
Wonder if anyone has ever found a good answer?
I was looking for you to post this tool next :D
Re: Shop tool mods
Not yet. I've drooled over the current crop of new woodworking drill presses. My ultimate goal is a full size milling machine with tilting head. That should handle anything I want to drill but would severely damage my wallet. :)
Mike Foster
Very nice John. I always meant to do that with my 14" bandsaw and never did.
