Re: Nobody has mentioned foot switches,
charlie_belden
I've used a foot switch - but the set up required that the switch on the lathe was ON before the footswitch would work as a remote secondary on off switch. This way, when mounting a blank, setting the tool rest and checking for clearance by manually turing the piece - the lathe's switch is ALWAYS OFF. Only when the lathe's swtich is turned back ON does the foot switch control power to the lathe's motor.
For spindle work and smaller turnings, the foot switch worked great. Could get the tool in position in tight places and then turng the lathe on without getting the tool out of position. Also worked well when a cut into a tight space was done and I want the lathe off before I extracted the tool.
But for bowl work and hollow forms, where you may have to move your feet - or try and keep one foot on the switch and still get the range of movement required - it was like Indian Wrestling - where one foot has to stay planted while the rest of you is moving all over the place trying not to fall over. Foot switch then was more hassle than benefit.
Since I don't turn green - or large stuff - piles of shavings weren't a problem. But the foot switch I had wasn't sealed, so chips and crap would get into it and would have to be cleared in order for the switch to work. Tried it in a ZipLok bag, but stuff still got into the switch
