The Ultimate capture ring
Every time I go home to my parents I see this piece they brought back from their trip to spain. Don't know why they bought it but it should be the ultimate goal of all captured ring goblet turners I finally remember to take a photo so I could share it with you guys. The Angel does slide up and down on the goblet. Don't know how they did that unless it's somehow glued and/or screwed together inside because the hole is only a little larger than the stem of the goblet and you can't see any joint.
I have don that in the past by putting a small tenon on one end of the stem and a mortise on the other. Then glue was applied to the tenon and the whole thing fit together inside. In my case it was solid sphere.
Re: The Ultimate capture ring
Dennis in Southern Oregon
John, I'm guessing that the stem was parted off at the bottom of the fat bead on the cup, an under-sized hole was drilled in the fat bead and the stem was driven into the bead with careful grain matching. Another possibility: The stem may have been parted at a point that remains within the angel over its full sliding range, and both pieces drilled to accept a thin steel rod which would reinforce a butt glue joint that becomes hidden within the angel. Otherwise, looks like must be a 4-dimensional turning. :D
Dennis
