Good heavens, help me. I feel like such a dufus. I want to connect my power cord to my new engine (that will power my new belt sander!!). How do I do it??? Do I use the red connector and sandwich it under the nut? OR do I use the blue connector and slip it onto the prongy-thingy? I assume the green wire is connected to the green screw for grounding...right? And which wire goes on which connector to get it to rotate counterclockwise (is the white wire supposed to be the 'red' one)?
Go ahead, laugh at my incompetence, but then HELP me....please.
I received a very helpful phone call from Clifford, and he walked me through it, which was reinforced by your response Galen. Thank you both SO much!
Funny thing, even though the label notes the factory positioned connections should have it running counter-clockwise, it ran clockwise. I switched the two, and now it runs the way I want.
Bill, you are very gracious, but when it comes to electrical stuff, 'dufus' is an apt moniker. I am now one step away from the label though, thanks to Clifford and Galen.
Molly, I worked with industrial maintenance technicians for forty years. They asked the same questions as you did. Congratulations , you asked for help!
I am glad you have gotten your new toy together OK and have it play nicely with you! (I suppose I'd not hesitate to take advice from Galen - he lives here in Ames and is an active member of our club!) It looks like the "you finish building it" belt sander from Lee Valley - is that correct?
I have looked into getting one of these, given that I have at least half a dozen or more spare motors around here. Looks like a good deal....?!?!
Once you have given it a bit of a workout, could you please post how you like the machine in general? Will you be using it primarily for sharpening, or will it be mostly for use on wood?
.... that the motor does not appear to be a TEFC type, and thus, you should try to fit it up with something (shield, vacuum port, etc.) to reduce dust and particle infiltration into the motor itself while in use. Build up of wood or metal dust, and perhaps worse, abrasive grit particles, can do some serious damage to the motor's innards.
Just something to think about.
(Don't forget to protect your eyes and lungs while using it too!!)
I will be primarily using it for sharpening. When I taught up at the Lee Valley store this past year, they had three of them to use in the classroom. Part of my class was making miniature hollowing tools out of allen wrenches, and these sanders were slicker than snot to use. One of the things I liked so much was the ease in changing the sanding belts. In seconds I could go from an aggressive 60 grit, to a polishing 220 (and can go much finer). Right now I intend to use it for all my tools that aren't gouges. I still use my Wolverine for them, and like the consistency I get.
I'll try to remember to let you know how I like it after having it in my shop, but if I forget (dang short-term memory), remind me.
Thanks for the advice on shielding it from dust. I'll see what I can rig up.
