chainsaw oiler problems?
Steven Antonucci
Any clues how to fix one? Saw isn't throwing any oil, and it doesn't appear to be clogged?
Steve
Steven Antonucci
Steve
Re: chainsaw oiler problems?
d
Steve, don't know how you checked your oiler to see if it's plugged. Sounds like it could be. If you are operating in cold temperatures like we have in Utah now 4 degrees you'll need a thinner oil. Might also want to adjust your oiler controls up to see if you can get some success.
d
Wait a minute, weren't you supposed to clean your shop? :-0
50 gallons of shavings today!
Galen Vetterick
Not sure what you mean by not plugged. If you remove the bar and push the manual oiler you should see it run out the oil hole feeding the bar. If not I have had wood chips get in the oil tank and plug the system passage. I have drained the oil tank and used a large syringe to backflush into the passage. (used a turkey baster once). From the oil hole in the bar is the sloted passages to the bar groove open. This is the most common passage I have plugged. Clean the bar slot too so it has room to pull the oil around. My saw has adjustment for oil feed rate that can be adjusted as well. increase the feed for a while it may help unplug a minor problem. Change the oil weight too if so noted in your manual. I used an off brand once that was way to thick for my saw. Like thick honey, bad!
It's been a while since I even read my manual how about you?
Don in Central Illinois
Manual, what's a manual?
Manual-The "packing paper" that came with the saw.
Galen Vetterick
Kinda like packing newspaper that had pictures and typed words on it. Might have even had the words WARNING on it in many places.
The manual?
steven antonucci
If the manual for the saw even suggested that there was an oiler, I'd be happy. The manual actually doesn't even have a sentence about the topic...
I think my saw (Stihl O17) has some uniqueness to it. I haven't found any online sources yet that show a schematic of the oiler system or even where the oil holes might be? I'll drain it tomorrow to see if I can blow it out with some compressed air.
Steve
Re: Manual-The "packing paper" that came with the
Oh, that's a manual. Should be in the shop somewhere.
Re: The manual? *LINK*
Galen Vetterick
Steve a copy of the on-line manual page 31 does cover proper oil usage and the potential for seizing the rotary oil pump it has. Page 38 shows the location of the oil passage and the hole location in the bar. Without seeing it the hole may be close enough to the bar edge it directly foods the bar groove and no passage from the hole out to the goove like mine.(other brand). Yours does not then have a manual button to "add" bar oil feed manual nor any adjustment to the oil pump. Wonder since they say you should always have oil when you run out gas if you ran out of bar oil could it seize the rotary pump as well? Not a very good design if it can. Says the bar and chain must match so have you changed either? Calls the chain an oilmatic saw chain so wonder if there is something unique about it to better draw chain lube to groove???
http://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/017_018_Manual.pdf
You might take the bar off, and start it,
Keith Newton
With no bar and chain, you should see the oil flow out a little hole. If it does, the problem is downstream of there.
Have you changed the bar recently? If you got the wrong one, the oiler hole in it may not line up with the saw hole.
might have fixed it
Steven Antonucci
I took the bar off and drained the oil tank last night. This AM, I sprayed the oil filter with wd40 and hit the oil port with wd40 and a couple of shots of compressed air. I ran the saw for a few seconds without the bar on it, and it appears to be working again.
Thanks for all of the advice.
Steve
