For you coring experts out there, how "finished" are your cores?
I am making a tenon on the largest bowl to hold it, and then coring the inner bowls from smaller to larger. The last bowl gets "recut" to make it uniformly thick for drying purposes, but the inner cores... I just throw them in a leaf bag? They are fuzzy and close enough for drying.
Also, do you restack your cores back inside of each other to dry them? I probably have 50 bowls in bags and boxes, and expect to double that in the next week. I don't think I'll care about "matching sets", but yield instead. Does restacking them help/hurt drying?
I finish turn all of mine. I like the warped bowls. So, drilled recess on top, finish turn the bottom with another recess, reverse, take biggest core, finish turn the inside. Remount the core using drilled recess, and repeat. Soap soak, wrap rim in plastic stretch film, dry and ready to sand in a week or two at the most.
For now: I do what you do, then reverse each rough-out and use the inside of the next-larger bowl as a large friction chuck, with cored blank held between centers. I then clean up the outside and shape a tenon for later, being sure to leave a little nub with the tail center mark for re-chucking when dry.
Later: What I want to get is a set of knives curved the other way, and core from biggest to smallest, from the headstock end. That way you make one faceplate fixture, shape the outside, and as each bowl blank is removed, you have access to the foot of the next smaller bowl, so you can go ahead and make the next tenon, etc... The coring can be done with tailstock support, too.
I've done this with a friend and turning mentor who's a professional turner in New Hampshire (Dustin Coates, in Etna, near Dartmouth College), and he has a home-made lathe he uses to core huge bowls, up to about 36" or so. Works pretty slick, and saves time. He's bent all his reverse-curve McNaughton handles at almost 90 degrees for headstock clearance, and its really something to watch him core a dozen bowls in about an hour. He's very comfortable coring bowls at fairly high speed with no handle attached... looks scary, but he thinks the handles are not needed.
I'm also pretty careful to bevel all the rims and edges, so there's no thin edge to dry too fast and start a crack, so I bevel the inside and outside of the rim, and even put a tiny bevel on the tenon. I rarely lose a single blank to cracking, and I only coat wood that really moves a lot (Apple, Beech, etc...) or very high-value wood that would be a bummer to lose. Most Maple, Cherry, Ash, etc... is left un-coated, and they get tossed 4-5 at a time in a cardboard box, or singly in a paper shopping bag. I never nest them when wet because they are less likely to dry and more likely to spalt/mold/mildew/get slimy.
A few bowls get turned to finish right away. Typically my cores are stacked and left to dry several months before a final turn. No wrap, no seal, nothing... unless figured or otherwise special wood is involved. Specials are rough turned and get anchorseal on the end grain (inside and out). I do knock the corners off the rims just slightly. I lose very few. I have about 150 or so drying on the shelf at this time.
Brad said: "I never nest them when wet because they are less likely to dry and more likely to spalt/mold/mildew/get slimy." I recommend that you pay attention to that...he is absolutely correct.
Nesting them will somewhat depend on your location. If you live where it is very dry and hot then nesting will work fine. As a general rule I dry mine as I would dry any gouged out bowl blank (un-nested). You should consider marking your blanks at the lathe like M for maple and the date. On a nested set I'll mark them M1 on all four from the nest so I know they go together in the event I want to make a nested set for someone. Once they are dry I will then nest the M1 group together and the M2 and so on. This doesn't mean you have to turn them as set but it helps stay organized and gives you more options. The smaller cores (about under 8") I don't bother putting the tenon or marking the nub since they are pretty easy to center and put a tenon on once dry. Anything larger and I'll tenon and mark center. Fuzz and all that shouldn't bother anyone since they are called Roughed out.
BTW congratulations, since you are asking these questions I am assuming you are having success. That is awesome.
I cored a smelly piece of apple that reeked so badly it was making me wretch. I lost the middle bowl because the shaving packed at the bottom of the second core, or I would have been close. Based upon the shape, I know that more careful setup and measurement will yield success.. as I wasn't really taking my time with the apple.
As I have very little storage space, I toss them around while I am coring, so they dry enough to "skin" but at the end of a seance, I do stack them with 3 sticks I don't coat them except beech and apple.
A few get turn to finished shape and oiled lightly. A few people like those, most people like round and smooth.
