PM 3520B interference with U-verse and computer
Larry528
Anyone have interference with "noise" from a PM3520B and their computer/U-verse system?
I have been using it for a week and lots (not all) of the time I fire it up, the computer and U-verse TV (they are on the same digital line coming into the house) craps out. It freezes the screen, then it goes off. The computer gives a signal lost message. It stays dead until I turn the lathe off,
UPDATE:
Tonight I discovered after talking to my wife about when she would come out when it died that it was with me sanding and the lathe going slow. So after dinner I turned it on at a fast speed, and would wait about 30 seconds, lower the speed, so on, at less than 200 the freeze would happen. Turn it off, wait for the computer/TV signal to return and restart lath and raise speed. At higher RPM its OK. So while I must do sanding at speeds above 200 if she is home, I cant go slower than 200.
Any one have a similar problem, and any fix?
I have read about using ferrite chucks, magnets that go over the power cord. Like those round bumps found on lots of computer cords. But for a 240 line, I am not sure.
Do other PM users have this problem and what did you do about it. Telling her to get cable isnt really an option.
Re: PM 3520B interference with U-verse and computer
Rob Wallace
Dealing with Radio Frequency Interference (long)
Rob Wallace
From your description, it sounds like RF is being emitted from the electronics of your variable speed controller, and it is overwhelming the TV receiver front end.
First, I hope you mean a ferrite CHOKE - chucks should still be made of steel (!).....
If the system relies on pulse width modulation to drive the motor at different speeds, the PWM or trigger frequencies at the low end of your speed range appear to be of the correct frequency (or harmonics thereof) to outcompete or "saturate" the incoming desired TV signal, and blank-out the digital video information, giving you the "lost signal" indication. At higher lathe speeds (and thus higher pulse frequencies) it appears that the interference is reduced. Although I obviously haven't measured anything in your system, from what you have described, this would be my guess about what is happening until data prove otherwise.
There are several possibilities of how to reduce the interference. If the RF is being propagated by the power line to the speed controller, a ferrite choke placed as close to the electronics housing as possible might attenuate the interfering signal enough for the TV signal to come through the noise and be decoded. If a toroidal type choke is used to create a high impedance "bump" on the power line of the lathe, you may need to wind several turns of the power cord through the toroidal ferrite core (BTW - the ferrite matrix material is rated by frequency, so some investigation might be necessary as to which ferrite core material will give the best attenuation at the particular frequencies needed). (It probably wouldn't hurt to put an RF choke on the power line going into the TV receiver unit too.)
If the interfering RF being generated is propagating directly from the electronics unit itself, additional grounding (i.e. low impedance ground straps) and/or bypassing connections with appropriate capacitors might be necessary. The worst case scenario would be that additional shielding (i.e. putting a grounded metal box around the electronics unit) might reduce the interference to an acceptable level.
Alternatively, if the RF is coming in through the TV coaxial cable, be sure the coax shield conductor at all points of connection makes good physical and electrical contact at all connectors (for example, crimp-type "F" connectors sometimes do not make very good contact with the coax shield), and that the whole system is adequately grounded. Placement of several ferrite beads on the outside of the coax itself, near the TV input, (or other RF filtering at the TV coax end) might be needed to attenuate interfering RF from riding into the TV unit on the coaxial cable. Modern digital cable/TV systems use a double shielded RG-6 type coax with foil; older systems may be still using RG-59 type coax cable which provide far less RF shielding and could be problematic with respect to RF interference.
Troubleshooting RF Interference situations are often a step-by-step process of elimination, fixing the most likely culprits first, and continuing the process until the situation is resolved. Each installation is somewhat unique, and requires some knowledge of how the RFI is generated, how it is received, what possible steps to take first (and next), along with a good bit of deductive reasoning and A LOT of patience.
Good Luck!
Rob
(.....a survivor of many RF interference situations over the past 35+ years as a ham radio operator...)
Re: PM 3520B interference with U-verse and compute *LINK*
Walta
Is the Uverse wired with Coax or cat5 cables?
If its Coax I would replace it with cat5
This link is my favorite Uverse form
Walta
dslreports
Rob, let me tap your vast knowledge,
Keith Newton
I have a different kind of RFI. It seems I am the interference. If I am active around the kitchen or office, my FM radio works fine, but about 10 to 30 seconds after I settle down with my morning cereal, about 20' away, I guess my aura expands, and I block the signal through the air. As soon as I start to get up to fix the tuning, it clears up.
If I am inside of about 3', there is no problem. My bedside clock alarm is set to NPR, and does the same if I happen to be in the middle of the bed when it goes off. If I reach over to hit the snooze button, it clears up. In the office, I ran the antenna under my desk-top, just inches away from my knees.
I'm just wondering if you have any suggestions, other than sleeping in an army helmet, and or dragging an ankle chain, to fix this abnormality. ha
Ralph Lindberg
Larry, please see my comments on the AAW forum, this is one of the fixes that I found in my research.
