Re: Hannes vector grind fixture (long)
Donna Banfield
Dick, Hannes really does use that Vector jig to sharpen his tools. Earlier this year he had a prototype at the New England Woodturning Symposium. It is now in full production. He was in my studio last month for my annual Open Turning event, and had these jigs with him.
Full disclosure here - I became a fan of his grind and his tools in 2007, and have been free-hand sharpening all my bowl gouges since. I'm also a big fan of his tools, as well, and own several. I teach private one-on-one woodturning sessions in my studio and my students have full access to use any of my tools. Many of my students end up buying Hannes' gouges.
I bought two of the Vector fixtures that day. Why? Because having several of my gouges with the grind that the Vector produces makes roughing out bowl blanks much faster. The grind is a bit more aggressive when compared to the free-hand grind. I loved the free-hand grind (as do many of my bowl-turning students) because it is nearly catch-free. I can roll a gouge with Hannes' free-hand grind completely on it's side, flute facing the wall, on the interior curve of a bowl, handle completely horizontal, and not get a catch. I could never do that with any other fingernail grind gouge, and not get a 3/4 inch divot alll the way around the inside wall. The trade-off to that is, it is not as aggressive at roughing out bowl blanks, which is what makes it catch-free. With the Vector grind, rolling the gouge on the side in the same manner will make it a little grabby, but I haven't gotten one of those 'fudge my huggies' catches I remember. So I have my larger gouges (3/4" and a few 1/2") sharpened with the Vector grind, and I keep a few of my bowl gouges with the free-hand grind. But, I've also just walked up to the grinder and did a quick touch-up free-hand on the Vector grinds, too. In that case, I'm just refreshing the edge to take a final cut.
To sharpen, you start with the two outside pivot points, (far left and far right on the plate) which give you your primary micro-bevel. The center pivot point on the same plane blends the tip of your gouge with the micro-bevel. The next two forward pivots allow you to remove the heel of the gouge. Once set up on the grinder, I leave the Vector in the slide arm; it works on all his gouges (or any gouge that you choose to put that grind on), regardless of size (3/4, 1/2 and 3/8) because the bevel is always a constant 40 degrees.
I hope that this helps.
