I AM NOT A HAPPY CAMPER
charlie belden
The bearings on my little JET VS Mini gave up the ghost, and took my drive spindle with them, resulting in runout of three or four thousandths. For Flat Work, being off by 0.006 to 0.008 inches is no big deal. BUT – if you’re turning miniatures and delicate finials to go with them . . .
On Sunday, December SECOND, before noon, I ordered the replacement bearings and drive spindle from eRAPLACEMENTPARTS and was told I’d have them in “10 or 11 business days at the latest”. That would get them to me by the 17th or the 18th. THAT would give me some time to turn the Christmas presents I WAS going to make.
Being an optimist, I started listening for the UPS or FEDEX truck a week later. In that time UPS and FEDEX delivered a lot of stuff – to my immediate neighbors – but nothing for me.
Saturday, Decmber 15th, I went to the eREPLACEMENTPARTS site to see when my order was shipped.
What I found out was that my order showed a SHIP BY date of
- wait for it –
DECEMBER 24TH!
Figuring “5 to 7 Working Days” for shipping time, I’ll get my parts - NEXT YEAR!
To say I am NOT A HAPPY CAMPER, or more concisely, NOT A SATISFIED CUSTOMER, would be a gross understatement.
The lesson to be learned from this tale? When ordering parts, if you’re told the parts are Not In Stock and will have to ordered from the OEM – FIND ANOTHER SOURCE!
Yes, Viirginia, there really is a GRINCH.
Re: I AM NOT A HAPPY CAMPER
Alan Zenreich
Alan Zenreich
Alternate moral of the story: You can't have too many lathes.
David Walser
Charlie,
I feel your pain! On the upside, it sounds like you still have time to find another source (and cancel your order before it is shipped). Your parts might not arrive earlier, but you'll have the satisfaction of canceling.
Maybe the "upside" isn't worth the trouble of finding another source.
David
Dick Coers
Talk to an electric motor rebuild shop. I had a special frame motor from an Italian sliding table saw go bad. They had some method of spraying something on the shaft to build it up. I had the idea it was metal powder, but my memory fails me. Bearings are easily available locally, so you might be up and running in a couple days. The coating may not take long term loading, but ask them anyway.
Galen Vetterick
If you really need a replacement spindle you probably just have to wait. The bearings you can probably buy local from the numbers on the bearings. My Jet 1220 belt driven are KBC bearings with one at 6005DD C3G14 and the other 6004DD C3G81. They actually sent them in error and told me to just keep. They also sent me soneones large metal lathe coolant recirculation pump too and told me to keep it too! Like now I just need a big metal lathe! :D
Not sure where you are........
Richard Jones
but you are welcome to a spare Rikon mini that I have.........
Charlie You didn't say how the spindle was ruined. I'm assuming it started rotating on the bearings. I have repaired one by dimpling the bearing seating area with a center punch. Then put it in a metal lathe and turned the raised area left by the punches down to the proper size. This way the bearings had a press fit and the shaft was centered.
Oh I forgot to tell you. On that lathe you get runout when the hand wheel is not tightened fully. You probably did have it tightened but it could simply be the slop in the old bearings created the runout. Did you try new bearings. You can buy those locally. They are not an odd size.
Dale Jablonski
Dale Jablonski
Gotta look on the bright side if you can. You'll get your parts unless the Mayans are right in which case forgetaboutit.
Last summer I had to deal with a trifecta. My Shopsmith's control sleeve went out, then my truck transmission followed and finally by then means of transportation...my bike went down. Thank the Lord the lathe was still up but not having my bandsaw put a kink in our inventory.
The Shopsmith part and the tranny took the longest and I was definitely not a happy camper! I had a good lesson in patience.
Re: Turn something for Charlie
Terry Scott
Charlie yep shipping can be a pain in the tailstock
Your welcome to use my lathes if you want to.
Well you would be if you lived a little closer
Maybe someone up your way could turn a few things that you requested to help you out.
Once again id only be to happy to make something but you'd most likely get in 2014 the way the mails going this year
Cheers
McMaster-Carr or Grainger, maybe Enco
Craig Daymon
Get the bearings from one of those companies and it will usually be at your door in 2 days. I've even had things ordered in the morning show up after noon. I replaced the bearings in my JET mini years ago and ordered better bearings, I think from McMaster-Carr. Their site also has good information to tell you the difference in which bearings would be better/longer lasting/more rugged. Sorry I didn't post this sooner, I thought it would be somewhere in the other posts.
Thanks for the heads up
Ralph Lindberg
....another place to avoid when you actually have dead-lines
Goes on my list with PennState; average time to ship, over the last 5 years is 6 days. While Craft Supplies is 90% on the day of order and the rest the next day.
Try here  *LINK*
USA Belts and Bearings
Thanks to all - and The Rest of the Story
charlie belden
Thanks to all who responded to my tale of woe and semi-rant.
I got another e-mail from eREPLACEMENTPARTS informing me that my parts were to be shipped today (Dec, 19th) - via the US Postal Service - and I "should" get them in "3 to 5 working days". So, best case, I MAY get them late Saturday (Dec. 21st), worst case I'll have them Tuesday (Dec. 24th).
Looks like I'll be wrapping chunks of wood and include an IOU in each present.
Now The Rest of the Story
When I rewired the variable speed controller on my VS Mini, I replaced the ON/OFF switch with a Three Way Switch - Foreward/OFF/Reverse (DOWN=foreward, HORIZONTAL=off, UP=reverse). Worked great and didn't require adding a separate switch box to the controller box.
I'd roughed a largish chunk of wood to the basic shape I was after and turned up the speed to begin refining it. A hidden bark inclusion kicked off a catch that put the spinning piece off center and the chuck grip was loosening FAST.
Quickly flipped the switch to OFF and right past OFF - to Reverse.
SURPRISE, SURPRISE, SURPRISE! Bearings and shafts and belts don't like changing directions that fast, especially when you've got the inertia of 5 pounds of spinning metal and wood attached to the shaft. The bearings gave out first and that damaged the drive spindle shaft AND the V belt.
The bearings I was able to find locally, but since I had to replace the drive spindle and belt, without which the lathe was still useless, I ordered all the needed parts on line
