motor problem
motor problem
motor problem
Brian
When I put pressure on the wood I am turning the motor clicks and slows down, when I remove the tool it starts back up but any pressure on the wood and the motor seems to turn off. Run capacitor? or any other ideas. (not too sure what a run capacitor is )
Brian
Re: motor problem
Re: motor problem
John Veerkamp
Need more information. Make of lathe. Electronic variable speed? , size of motor?
Re: motor problem
Re: motor problem
JMOHNIKE
When that happens to one of my motors, I take it apart and clean it. If the motor is an open frame motor, it can get filled with sawdust and not allow the motor to run at full speed. When you start to cut it slows it down even more. Cleaning it may help, if it is a common motor, get a new one, as the cleaning is only a temp. fix.
Re: motor problem
Re: motor problem
Brian
It is a Harbor freight 12X36" 3/4 horse 120 V 60Hz 1700 RPM ( no load) It has a lver you move to change the speeds. Also If I am at High RPM and push the lever to slow it down the motot clicks off and on.
I have had no problems with it up until now and have no real complaints up until this. Besides the fact that I want a much larger more powerful toy.
I am guessing it has something to do with the increase in "load:. I may not mean load in the truly electrical sense, but maybe since I have no idea ;-)
Brian
Re: motor problem
Re: motor problem
Josh Bowman
The start capacitor is just that, it's only in the circuit during the spin up. After that it's out. I'd be surprised that a HF motor had a run capacitor. Sounds like.......maybe that some of the run winding's have shorted out or opened. Basically meaning you have much less HP. Could also be a lot of friction in the bearings or bad bearings, friction from the belt or spindle bearings. Take a wooden dowel and try to listen to the bearings by placing the end of the dowel on the bearing and the other end near your ear. The wood will transfer the sound and help you localize where the problem is. You may have to have someone load the lathe up by doing some turning while you do this. Do this at each bearing, probably 2 on the spindle and 2 on the motor.
Re: motor problem
Re: motor problem
Joe Dickason
Sounds like the HF lathe that I have. I burnt one motor up by overworking it. I found that I could buy a new motor for $40, so I ordered 2. Still have a spare. Your manual that came with the lathe will give you Pt# & contact info.
Re: motor problem
Re: Reeves Drive ?
Doc Green
Doesn't that lathe have a Reeves drive? If so, I'll bet the problem lies in that area.
My first lathe was a Sears with a Reeves drive. Constant PITA.
~Doc
Re: motor problem
Re: Reeves Drive ?
Nick Todd
Along Doc's thought, I think the pulley inside of the head stock or on the motor is widening from the pressure.
Take the cover off the head stock and you should be able to see if that is the problem.
Re: motor problem
Re: motor problem
Roger
How heavy is the piece you are trying to turn? If you are trying to turn a piece that is very heavy, and has a large diameter, you may just not have enough torque to keep it going when you put the gouge to it.
Re: motor problem
Re: motor problem
Terry Scott
Brain
Id soon get slacked of trying to sort out the problem and buy a new bigger more hp lathe
This would be after my final try to fix with a big hammer
Re: motor problem
Re: motor problem
brian
That could very well be the problem. Green 9x9 hunk of walnut. I will try something smaller to see if that us the problem.
The lather has served me well for the last 8 months I have had it. Would love a bigger more powerfully lather, but not going to happen any time soon.
