Re: Yes
Bill Jacksonville, NC
Why do we sand our woodturnings? Guess we want to even out wood surface, remove tool marks, before apply a finish. How much sanding we do depends upon damage we did to wood, species of wood, and finish going to use.
Did not forget intended use of the item we turned. Some instances exist where no finish used so may sand to higher grits. So no sanding bare wood to 2,000 or 3,000 grits not always necessary but does not hurt anybody when needed.
Might want to sand to higher grits if going to use oil or oil blend as a finish. Have read where cannot see scratches after sanding with 400 grit, we know that is not true.
Film finish manufacturers seldom recommend sanding higher than 320 grit. If select a film finish that benefits from rubbing out might want too wet or oil sand using higher grits.
